First, some “simple” SC violations are selected. By “simple” it is meant that the tests are critical ones, contain no instruction other than memory accesses and have two or three threads. Memory types may vary though.
We then show how to restore SC by using exchange instructions and memory fence mfence instructions, regardless of memory types. We also show that using sfence instructions does not suffice.
| Model | Hardware | CoreI5 | CoreI5-dual | CoreI7 | Chianti | Limoux | Teraram | Estephe | Barsac | Zdani | |
| 2+2W+WB+WC | Allow | Ok, 355M/4.3G | Ok, 78M/890M | Ok, 26M/300M | Ok, 70M/560M | Ok, 32M/991M | Ok, 55M/504M | Ok, 80M/553M | Ok, 69k/66M | Ok, 14M/173M | Ok, 690k/267M |
| 2+2W+WC+WC | Allow | Ok, 4.7M/4.3G | Ok, 931k/890M | Ok, 279k/300M | Ok, 1.2M/560M | Ok, 1.2M/991M | Ok, 253k/504M | Ok, 541k/553M | Ok, 26k/66M | Ok, 204k/173M | Ok, 100k/267M |
| MP+WB+WC | Allow | Ok, 37k/4.3G | Ok, 36/890M | Ok, 154/300M | Ok, 49/560M | Ok, 124/991M | Ok, 994/504M | Ok, 34k/553M | No, 0/66M | Ok, 1.8k/173M | Ok, 56/267M |
| Allow unseen | |||||||||||
| MP+WC+WB | Allow | Ok, 260M/4.3G | Ok, 76M/890M | Ok, 16M/300M | Ok, 68M/560M | Ok, 19M/991M | Ok, 21M/504M | Ok, 50M/553M | Ok, 73k/66M | Ok, 11M/173M | Ok, 1.2M/267M |
| MP+WC+WC | Allow | Ok, 108k/4.3G | Ok, 15k/890M | Ok, 25k/300M | Ok, 21k/560M | Ok, 6.4k/991M | Ok, 13k/504M | Ok, 25k/553M | No, 0/66M | Ok, 2.8k/173M | No, 0/267M |
| Allow unseen | Allow unseen | ||||||||||
| R+WB+UC | Allow | Ok, 31M/4.3G | Ok, 3.2M/890M | Ok, 5.3M/300M | Ok, 1.1M/560M | Ok, 8.5M/991M | Ok, 12M/504M | Ok, 774k/553M | Ok, 16/66M | Ok, 641k/173M | Ok, 18k/267M |
| R+WB+WB | Allow | Ok, 30M/4.3G | Ok, 3.3M/890M | Ok, 2.5M/300M | Ok, 2.3M/560M | Ok, 11M/991M | Ok, 6.3M/504M | Ok, 2.3M/553M | Ok, 51k/66M | Ok, 947k/173M | Ok, 754k/267M |
| R+WB+WC | Allow | Ok, 380M/4.3G | Ok, 78M/890M | Ok, 25M/300M | Ok, 68M/560M | Ok, 50M/991M | Ok, 56M/504M | Ok, 83M/553M | Ok, 194k/66M | Ok, 15M/173M | Ok, 5.9M/267M |
| R+WB+WT | Allow | Ok, 22M/3.3G | Ok, 3.1M/890M | Ok, 5.3M/300M | Ok, 1.0M/560M | — | Ok, 12M/504M | Ok, 839k/553M | Ok, 11/66M | Ok, 575k/173M | Ok, 12k/267M |
| R+WC+WB | Allow | Ok, 288M/4.3G | Ok, 77M/890M | Ok, 26M/300M | Ok, 71M/560M | Ok, 24M/991M | Ok, 25M/504M | Ok, 54M/553M | Ok, 56k/66M | Ok, 9.4M/173M | Ok, 607k/267M |
| R+WC+WC | Allow | Ok, 202k/4.3G | Ok, 7.6k/890M | Ok, 18k/300M | Ok, 15k/560M | Ok, 10k/991M | Ok, 36k/504M | Ok, 110k/553M | No, 0/66M | Ok, 5.3k/173M | Ok, 1/267M |
| R+WT+UC | Allow | Ok, 3.2M/3.3G | Ok, 410k/890M | Ok, 171k/300M | Ok, 192k/560M | — | Ok, 1.3M/504M | Ok, 740k/553M | Ok, 38/66M | Ok, 357k/173M | Ok, 9.2k/267M |
| R+WT+WB | Allow | Ok, 601k/3.3G | Ok, 105k/890M | Ok, 35k/300M | Ok, 51k/560M | — | Ok, 79k/504M | Ok, 295k/553M | Ok, 22/66M | Ok, 30k/173M | Ok, 6.1k/267M |
| R+WT+WC | Allow | Ok, 474M/3.3G | Ok, 95M/890M | Ok, 31M/300M | Ok, 85M/560M | — | Ok, 126M/504M | Ok, 111M/553M | Ok, 5.4k/66M | Ok, 26M/173M | Ok, 800k/267M |
| R+WT+WT | Allow | Ok, 3.4M/3.3G | Ok, 526k/890M | Ok, 174k/300M | Ok, 213k/560M | — | Ok, 1.3M/504M | Ok, 741k/553M | Ok, 46/66M | Ok, 384k/173M | Ok, 6.4k/267M |
| S+WB+WC | Allow | Ok, 16k/4.3G | Ok, 32/890M | Ok, 35/300M | Ok, 76/556M | Ok, 7/991M | Ok, 429/504M | Ok, 14k/553M | No, 0/66M | Ok, 707/173M | Ok, 32/227M |
| S+WC+WB | Allow | Ok, 325M/4.3G | Ok, 68M/890M | Ok, 23M/300M | Ok, 63M/556M | Ok, 29M/991M | Ok, 54M/504M | Ok, 73M/553M | Ok, 32k/66M | Ok, 14M/173M | Ok, 314k/227M |
| S+WC+WC | Allow | Ok, 263k/4.3G | Ok, 8.0k/890M | Ok, 16k/300M | Ok, 14k/556M | Ok, 14k/991M | Ok, 87k/504M | Ok, 111k/553M | No, 0/66M | Ok, 13k/173M | No, 0/227M |
| SB+UC+WT | Allow | Ok, 17k/2.9G | Ok, 486/778M | Ok, 305/236M | Ok, 697/432M | — | Ok, 2.3k/408M | Ok, 13k/553M | No, 0/66M | Ok, 869/173M | No, 0/227M |
| SB+WB+UC | Allow | Ok, 5.9M/3.8G | Ok, 498k/778M | Ok, 904k/236M | Ok, 26k/432M | Ok, 3.1M/927M | Ok, 1.0M/408M | Ok, 379k/553M | Ok, 5/66M | Ok, 73k/173M | Ok, 3.0k/227M |
| SB+WB+WB | Allow | Ok, 165M/3.8G | Ok, 9.4M/778M | Ok, 7.5M/236M | Ok, 4.7M/432M | Ok, 106M/927M | Ok, 14M/408M | Ok, 13M/553M | Ok, 347k/66M | Ok, 4.5M/173M | Ok, 5.2M/227M |
| SB+WB+WC | Allow | Ok, 269M/3.8G | Ok, 66M/778M | Ok, 22M/236M | Ok, 58M/432M | Ok, 37M/927M | Ok, 10M/408M | Ok, 60M/553M | Ok, 159k/66M | Ok, 10M/173M | Ok, 5.7M/227M |
| SB+WB+WT | Allow | Ok, 84M/2.9G | Ok, 24M/778M | Ok, 12M/236M | Ok, 19M/432M | — | Ok, 12M/408M | Ok, 7.5M/553M | Ok, 103k/66M | Ok, 3.1M/173M | Ok, 6.8M/227M |
| SB+WC+WT | Allow | Ok, 230M/2.9G | Ok, 65M/778M | Ok, 23M/236M | Ok, 60M/428M | — | Ok, 10M/408M | Ok, 64M/553M | Ok, 10k/66M | Ok, 8.5M/173M | Ok, 843k/227M |
| SB+WT+WT | Allow | Ok, 103M/2.9G | Ok, 37M/778M | Ok, 5.1M/236M | Ok, 34M/428M | — | Ok, 9.4M/408M | Ok, 8.0M/553M | Ok, 204k/66M | Ok, 3.3M/173M | Ok, 5.7M/227M |
| RWC+WB+UC | Allow | Ok, 1.1M/1.9G | Ok, 39k/336M | Ok, 213k/82M | Ok, 9.4k/124M | Ok, 331k/447M | Ok, 359k/232M | Ok, 54k/318M | No, 0/33M | Ok, 66k/115M | No, 0/185M |
| RWC+WB+WB | Allow | Ok, 569k/1.9G | Ok, 32k/336M | Ok, 76k/82M | Ok, 8.9k/124M | Ok, 185k/447M | Ok, 54k/232M | Ok, 138k/318M | Ok, 1.3k/33M | Ok, 40k/115M | Ok, 35k/185M |
| RWC+WB+WC | Allow | Ok, 59M/1.9G | Ok, 5.8M/336M | Ok, 3.8M/82M | Ok, 3.0M/124M | Ok, 6.8M/447M | Ok, 4.2M/232M | Ok, 31M/318M | Ok, 37k/33M | Ok, 3.0M/115M | Ok, 853k/185M |
| WRR+2W+WB+WC | Allow | Ok, 64M/1.8G | Ok, 9.3M/336M | Ok, 4.2M/82M | Ok, 4.8M/124M | Ok, 6.7M/447M | Ok, 5.3M/232M | Ok, 30M/318M | Ok, 26k/33M | Ok, 3.6M/115M | Ok, 168k/161M |
| WRR+2W+WC+WB | Allow | Ok, 560/3.9G | Ok, 47/976M | Ok, 16/562M | Ok, 49/764M | No, 0/575M | Ok, 36/330M | Ok, 211/409M | No, 0/33M | Ok, 201/115M | No, 0/161M |
| Allow unseen | Allow unseen | Allow unseen | |||||||||
| WRR+2W+WC+WC | Allow | Ok, 1.0M/1.8G | Ok, 87k/336M | Ok, 451k/82M | Ok, 182k/124M | Ok, 13k/447M | Ok, 24k/232M | Ok, 9.2k/318M | Ok, 3/33M | Ok, 265k/115M | Ok, 25/161M |
| WRW+2W+WB+WC | Allow | Ok, 66M/1.8G | Ok, 7.9M/336M | Ok, 5.7M/82M | Ok, 4.3M/124M | Ok, 6.3M/447M | Ok, 6.4M/232M | Ok, 31M/318M | Ok, 14k/33M | Ok, 3.4M/115M | Ok, 99k/161M |
| WRW+2W+WC+WB | Allow | Ok, 380/3.9G | Ok, 40/976M | Ok, 7/562M | Ok, 49/764M | No, 0/575M | Ok, 18/330M | Ok, 116/409M | No, 0/33M | Ok, 150/115M | No, 0/161M |
| WRW+2W+WC+WC | Allow | Ok, 1.6M/1.8G | Ok, 108k/336M | Ok, 595k/82M | Ok, 214k/124M | Ok, 67k/447M | Ok, 83k/232M | Ok, 25k/318M | No, 0/33M | Ok, 514k/115M | Ok, 2/161M |
| WRW+WR+WB+UC | Allow | Ok, 786k/1.8G | Ok, 33k/336M | Ok, 40k/82M | Ok, 14k/124M | Ok, 81k/447M | Ok, 301k/232M | Ok, 117k/318M | No, 0/33M | Ok, 200k/115M | No, 0/161M |
| WRW+WR+WB+WB | Allow | Ok, 144k/1.8G | Ok, 8.0k/336M | Ok, 6.2k/82M | Ok, 2.4k/124M | Ok, 18k/447M | Ok, 13k/232M | Ok, 63k/318M | Ok, 430/33M | Ok, 13k/115M | Ok, 21k/161M |
| WRW+WR+WB+WC | Allow | Ok, 56M/1.8G | Ok, 3.2M/336M | Ok, 4.6M/82M | Ok, 1.7M/124M | Ok, 5.9M/447M | Ok, 7.1M/232M | Ok, 30M/318M | Ok, 22k/33M | Ok, 3.0M/115M | Ok, 283k/161M |
| 3.2W+WB+WB+WC | Allow | Ok, 49M/2.3G | Ok, 1.8M/392M | Ok, 4.7M/150M | Ok, 1.6M/228M | Ok, 7.3M/511M | Ok, 6.2M/336M | Ok, 26M/318M | Ok, 10k/33M | Ok, 1.8M/115M | Ok, 130k/185M |
| 3.2W+WB+WC+UC | Allow | Ok, 384/4.3G | Ok, 28/1.0G | Ok, 3/630M | Ok, 4/868M | Ok, 1/639M | No, 0/434M | Ok, 346/409M | No, 0/33M | Ok, 2/115M | No, 0/185M |
| 3.2W+WB+WC+WC | Allow | Ok, 93M/3.1G | Ok, 18M/552M | Ok, 5.8M/662M | Ok, 14M/324M | Ok, 9.0M/518M | Ok, 13M/346M | Ok, 28M/318M | Ok, 14k/33M | Ok, 4.6M/115M | Ok, 153k/185M |
| 3.2W+WC+WC+UC | Allow | Ok, 4.8M/2.3G | Ok, 1.9M/392M | Ok, 492k/150M | Ok, 961k/228M | Ok, 88k/511M | Ok, 640k/336M | Ok, 480k/318M | No, 0/33M | Ok, 187k/115M | Ok, 1/185M |
| 3.2W+WC+WC+WC | Allow | Ok, 22M/2.3G | Ok, 3.0M/392M | Ok, 4.6M/150M | Ok, 2.2M/228M | Ok, 1.6M/511M | Ok, 4.4M/336M | Ok, 4.4M/318M | Ok, 4.9k/33M | Ok, 1.7M/115M | Ok, 3.7k/185M |
| 3.SB+WB+UC+UC | Allow | Ok, 1.0k/4.9G | Ok, 4/1.1G | No, 0/1.1G | No, 0/900M | Ok, 3/614M | Ok, 84/380M | Ok, 875/409M | No, 0/33M | Ok, 47/115M | No, 0/185M |
| Allow unseen | Allow unseen | Allow unseen | Allow unseen | ||||||||
| 3.SB+WB+WB+UC | Allow | Ok, 3.9M/2.0G | Ok, 97k/336M | Ok, 231k/118M | Ok, 41k/164M | Ok, 2.6M/479M | Ok, 363k/272M | Ok, 255k/318M | Ok, 73/33M | Ok, 232k/115M | Ok, 22k/185M |
| 3.SB+WB+WB+WB | Allow | Ok, 33M/2.0G | Ok, 1.4M/336M | Ok, 1.0M/118M | Ok, 910k/164M | Ok, 26M/479M | Ok, 1.4M/272M | Ok, 1.4M/318M | Ok, 10k/33M | Ok, 525k/115M | Ok, 871k/185M |
| 3.SB+WB+WB+WC | Allow | Ok, 90M/2.0G | Ok, 9.4M/336M | Ok, 5.8M/118M | Ok, 7.0M/164M | Ok, 23M/479M | Ok, 5.6M/272M | Ok, 33M/318M | Ok, 92k/33M | Ok, 5.0M/115M | Ok, 1.3M/185M |
| 3.SB+WB+WC+UC | Allow | Ok, 1.5k/4.9G | Ok, 5/1.1G | Ok, 3/1.1G | No, 0/900M | Ok, 4/614M | Ok, 67/380M | Ok, 1.1k/409M | No, 0/33M | Ok, 318/115M | No, 0/185M |
| 3.SB+WB+WC+WC | Allow | Ok, 81M/2.0G | Ok, 8.4M/336M | Ok, 10M/118M | Ok, 7.9M/164M | Ok, 10M/479M | Ok, 18M/272M | Ok, 22M/318M | Ok, 54/33M | Ok, 4.6M/115M | Ok, 26k/185M |
| ISA2+WB+WC+UC | Allow | Ok, 184/5.1G | Ok, 4/1.2G | No, 0/1.1G | No, 0/964M | No, 0/646M | Ok, 1/444M | Ok, 175/409M | No, 0/33M | Ok, 4/115M | No, 0/185M |
| Allow unseen | Allow unseen | Allow unseen | Allow unseen | Allow unseen | |||||||
| ISA2+WB+WC+WB | Allow | Ok, 641/5.1G | Ok, 77/1.2G | Ok, 1/1.1G | Ok, 25/964M | Ok, 2/646M | Ok, 3/444M | Ok, 522/409M | No, 0/33M | Ok, 11/115M | No, 0/185M |
| ISA2+WB+WC+WC | Allow | Ok, 15/5.1G | Ok, 1/1.2G | No, 0/1.1G | Ok, 1/964M | No, 0/646M | Ok, 1/444M | Ok, 12/409M | No, 0/33M | No, 0/115M | No, 0/185M |
| ISA2+WC+WB+UC | Allow | Ok, 76M/2.3G | Ok, 18M/392M | Ok, 5.2M/150M | Ok, 14M/228M | Ok, 2.8M/511M | Ok, 5.1M/336M | Ok, 28M/318M | Ok, 278/33M | Ok, 3.2M/115M | Ok, 14k/185M |
| ISA2+WC+WB+WB | Allow | Ok, 43M/2.3G | Ok, 6.1M/392M | Ok, 1.5M/150M | Ok, 4.7M/228M | Ok, 1.6M/511M | Ok, 2.1M/336M | Ok, 25M/318M | Ok, 7.0k/33M | Ok, 1.9M/115M | Ok, 62k/185M |
| ISA2+WC+WB+WC | Allow | Ok, 64M/2.3G | Ok, 13M/392M | Ok, 2.9M/150M | Ok, 9.4M/228M | Ok, 4.1M/511M | Ok, 13M/336M | Ok, 18M/318M | Ok, 12/33M | Ok, 2.7M/115M | Ok, 3.5k/185M |
| ISA2+WC+WC+UC | Allow | Ok, 2.9M/2.3G | Ok, 596k/392M | Ok, 1.5M/150M | Ok, 349k/228M | Ok, 57k/511M | Ok, 53k/336M | Ok, 277k/318M | No, 0/33M | Ok, 71k/115M | Ok, 5/185M |
| ISA2+WC+WC+WB | Allow | Ok, 1.1M/2.3G | Ok, 380k/392M | Ok, 506k/150M | Ok, 174k/228M | Ok, 6.1k/511M | Ok, 11k/336M | Ok, 38k/318M | No, 0/33M | Ok, 16k/115M | Ok, 34/185M |
| ISA2+WC+WC+WC | Allow | Ok, 2.0M/2.3G | Ok, 632k/392M | Ok, 829k/150M | Ok, 350k/228M | Ok, 17k/511M | Ok, 21k/336M | Ok, 126k/318M | No, 0/33M | Ok, 70k/115M | No, 0/185M |
| W+RWC+WB+UC+UC | Allow | Ok, 2.4k/5.1G | Ok, 1/1.2G | Ok, 30/1.1G | Ok, 2/964M | Ok, 9/646M | Ok, 426/444M | Ok, 1.8k/409M | No, 0/33M | Ok, 136/115M | No, 0/161M |
| W+RWC+WB+UC+WB | Allow | Ok, 10k/2.2G | Ok, 4/392M | Ok, 14/150M | Ok, 3/228M | Ok, 27/511M | Ok, 143/336M | Ok, 8.0k/318M | No, 0/33M | Ok, 984/115M | Ok, 830/161M |
| W+RWC+WB+UC+WC | Allow | Ok, 104M/2.2G | Ok, 21M/392M | Ok, 16M/150M | Ok, 17M/228M | Ok, 6.0M/511M | Ok, 14M/336M | Ok, 27M/318M | Ok, 7/33M | Ok, 3.3M/115M | Ok, 30k/161M |
| W+RWC+WB+WB+UC | Allow | Ok, 1.1M/2.2G | Ok, 76k/392M | Ok, 224k/150M | Ok, 31k/228M | Ok, 313k/511M | Ok, 429k/336M | Ok, 32k/318M | No, 0/33M | Ok, 42k/115M | No, 0/161M |
| W+RWC+WB+WB+WB | Allow | Ok, 165k/2.2G | Ok, 7.6k/392M | Ok, 5.9k/150M | Ok, 6.8k/228M | Ok, 43k/511M | Ok, 23k/336M | Ok, 52k/318M | Ok, 168/33M | Ok, 11k/115M | Ok, 16k/161M |
| W+RWC+WB+WB+WC | Allow | Ok, 50M/2.2G | Ok, 6.8M/392M | Ok, 1.9M/150M | Ok, 5.1M/228M | Ok, 6.3M/511M | Ok, 3.5M/336M | Ok, 25M/318M | Ok, 12k/33M | Ok, 1.8M/115M | Ok, 336k/161M |
| W+RWC+WB+WC+UC | Allow | Ok, 13k/5.1G | Ok, 54/1.2G | Ok, 73/1.1G | Ok, 10/964M | Ok, 65/646M | Ok, 2.9k/444M | Ok, 7.2k/409M | No, 0/33M | Ok, 2.6k/115M | No, 0/161M |
| W+RWC+WB+WC+WB | Allow | Ok, 17k/2.2G | Ok, 182/392M | Ok, 179/150M | Ok, 111/228M | Ok, 227/511M | Ok, 563/336M | Ok, 13k/318M | No, 0/33M | Ok, 1.6k/115M | Ok, 654/161M |
| W+RWC+WB+WC+WC | Allow | Ok, 75M/2.2G | Ok, 13M/392M | Ok, 7.4M/150M | Ok, 8.9M/228M | Ok, 8.4M/511M | Ok, 13M/336M | Ok, 22M/318M | Ok, 175/33M | Ok, 3.5M/115M | Ok, 15k/161M |
| W+RWC+WC+WB+UC | Allow | Ok, 97M/2.2G | Ok, 13M/392M | Ok, 7.9M/150M | Ok, 9.2M/228M | Ok, 10M/511M | Ok, 23M/336M | Ok, 29M/318M | Ok, 110/33M | Ok, 4.4M/115M | Ok, 3.4k/161M |
| W+RWC+WC+WB+WB | Allow | Ok, 50M/2.2G | Ok, 7.7M/392M | Ok, 2.1M/150M | Ok, 6.0M/228M | Ok, 2.4M/511M | Ok, 3.0M/336M | Ok, 26M/318M | Ok, 7.1k/33M | Ok, 2.7M/115M | Ok, 69k/161M |
| W+RWC+WC+WB+WC | Allow | Ok, 102M/2.2G | Ok, 15M/392M | Ok, 8.5M/150M | Ok, 10M/228M | Ok, 10M/511M | Ok, 24M/336M | Ok, 29M/318M | Ok, 54/33M | Ok, 4.6M/115M | Ok, 4.0k/161M |
| W+RWC+WC+WC+UC | Allow | Ok, 2.1M/2.2G | Ok, 184k/392M | Ok, 178k/150M | Ok, 122k/228M | Ok, 30k/511M | Ok, 1.3M/336M | Ok, 237k/318M | No, 0/33M | Ok, 119k/115M | Ok, 3/161M |
| W+RWC+WC+WC+WB | Allow | Ok, 918k/2.2G | Ok, 259k/392M | Ok, 386k/150M | Ok, 147k/228M | Ok, 20k/511M | Ok, 15k/336M | Ok, 62k/318M | No, 0/33M | Ok, 29k/115M | Ok, 17/161M |
| W+RWC+WC+WC+WC | Allow | Ok, 2.6M/2.2G | Ok, 292k/392M | Ok, 295k/150M | Ok, 216k/228M | Ok, 32k/511M | Ok, 1.3M/336M | Ok, 266k/318M | No, 0/33M | Ok, 145k/115M | No, 0/161M |
| Z6.0+WB+UC+UC | Allow | Ok, 5.6k/5.1G | Ok, 2/1.2G | Ok, 34/1.1G | Ok, 4/964M | Ok, 73/646M | Ok, 544/444M | Ok, 4.7k/409M | No, 0/33M | Ok, 233/115M | No, 0/161M |
| Z6.0+WB+UC+WB | Allow | Ok, 5.3k/2.2G | Ok, 3/392M | Ok, 3/150M | Ok, 4/228M | Ok, 12/511M | Ok, 88/336M | Ok, 3.8k/318M | No, 0/33M | Ok, 768/115M | Ok, 601/161M |
| Z6.0+WB+UC+WC | Allow | Ok, 136M/2.2G | Ok, 24M/392M | Ok, 16M/150M | Ok, 19M/228M | Ok, 12M/511M | Ok, 19M/336M | Ok, 40M/318M | Ok, 14/33M | Ok, 5.9M/115M | Ok, 11k/161M |
| Z6.0+WB+WB+UC | Allow | Ok, 720k/2.2G | Ok, 8.2k/392M | Ok, 6.2k/150M | Ok, 7.9k/228M | Ok, 86k/511M | Ok, 353k/336M | Ok, 38k/318M | No, 0/33M | Ok, 221k/115M | No, 0/161M |
| Z6.0+WB+WB+WB | Allow | Ok, 64k/2.2G | Ok, 2.2k/392M | Ok, 289/150M | Ok, 2.1k/228M | Ok, 3.6k/511M | Ok, 6.9k/336M | Ok, 30k/318M | Ok, 10/33M | Ok, 3.8k/115M | Ok, 15k/161M |
| Z6.0+WB+WB+WC | Allow | Ok, 49M/2.2G | Ok, 2.0M/392M | Ok, 4.3M/150M | Ok, 1.7M/228M | Ok, 6.3M/511M | Ok, 7.6M/336M | Ok, 25M/318M | Ok, 7.2k/33M | Ok, 2.0M/115M | Ok, 126k/161M |
| Z6.0+WB+WC+UC | Allow | Ok, 25k/2.2G | Ok, 14/392M | Ok, 8/150M | Ok, 10/228M | Ok, 2.2k/511M | Ok, 5.8k/336M | Ok, 14k/318M | No, 0/33M | Ok, 3.1k/115M | No, 0/161M |
| Z6.0+WB+WC+WB | Allow | Ok, 10k/2.2G | Ok, 267/392M | Ok, 17/150M | Ok, 106/228M | Ok, 31/511M | Ok, 436/336M | Ok, 7.6k/318M | No, 0/33M | Ok, 1.0k/115M | Ok, 600/161M |
| Z6.0+WB+WC+WC | Allow | Ok, 92M/2.2G | Ok, 15M/392M | Ok, 8.0M/150M | Ok, 11M/228M | Ok, 10M/511M | Ok, 13M/336M | Ok, 30M/318M | Ok, 13/33M | Ok, 4.9M/115M | Ok, 3.2k/161M |
| Z6.0+WC+WB+UC | Allow | Ok, 70M/2.2G | Ok, 13M/392M | Ok, 4.5M/150M | Ok, 9.1M/228M | Ok, 3.2M/511M | Ok, 5.0M/336M | Ok, 31M/318M | Ok, 562/33M | Ok, 3.7M/115M | Ok, 1.5k/161M |
| Z6.0+WC+WB+WB | Allow | Ok, 45M/2.2G | Ok, 6.7M/392M | Ok, 1.4M/150M | Ok, 5.3M/228M | Ok, 1.8M/511M | Ok, 2.3M/336M | Ok, 25M/318M | Ok, 7.5k/33M | Ok, 2.1M/115M | Ok, 50k/161M |
| Z6.0+WC+WB+WC | Allow | Ok, 51M/2.2G | Ok, 9.0M/392M | Ok, 2.6M/150M | Ok, 6.4M/228M | Ok, 4.5M/511M | Ok, 11M/336M | Ok, 15M/318M | Ok, 14/33M | Ok, 3.2M/115M | Ok, 720/161M |
| Z6.0+WC+WC+UC | Allow | Ok, 3.0M/2.2G | Ok, 528k/392M | Ok, 868k/150M | Ok, 260k/228M | Ok, 70k/511M | Ok, 754k/336M | Ok, 409k/318M | No, 0/33M | Ok, 147k/115M | Ok, 3/161M |
| Z6.0+WC+WC+WB | Allow | Ok, 1.5M/2.2G | Ok, 416k/392M | Ok, 737k/150M | Ok, 199k/228M | Ok, 12k/511M | Ok, 19k/336M | Ok, 45k/318M | No, 0/33M | Ok, 24k/115M | Ok, 5/161M |
| Z6.0+WC+WC+WC | Allow | Ok, 3.2M/2.2G | Ok, 952k/392M | Ok, 1.3M/150M | Ok, 447k/228M | Ok, 20k/511M | Ok, 65k/336M | Ok, 246k/318M | No, 0/33M | Ok, 131k/115M | No, 0/161M |
| Z6.1+UC+WB+WC | Allow | Ok, 383/5.1G | Ok, 25/1.2G | Ok, 1/1.1G | Ok, 2/964M | No, 0/646M | Ok, 1/444M | Ok, 352/409M | No, 0/33M | Ok, 2/115M | No, 0/161M |
| Z6.1+UC+WC+WB | Allow | Ok, 79M/2.2G | Ok, 11M/392M | Ok, 4.4M/150M | Ok, 10M/228M | Ok, 10M/511M | Ok, 9.3M/336M | Ok, 31M/318M | Ok, 1/33M | Ok, 3.8M/115M | Ok, 2.3k/161M |
| Z6.1+UC+WC+WC | Allow | Ok, 2.1M/2.2G | Ok, 64k/392M | Ok, 3.9k/150M | Ok, 96k/228M | Ok, 150k/511M | Ok, 899k/336M | Ok, 617k/318M | No, 0/33M | Ok, 241k/115M | Ok, 1/161M |
| Z6.1+WB+WB+WC | Allow | Ok, 1.1k/2.2G | Ok, 7/392M | No, 0/150M | Ok, 1/228M | No, 0/511M | Ok, 4/336M | Ok, 1.0k/318M | No, 0/33M | Ok, 12/115M | No, 0/161M |
| Z6.1+WB+WC+UC | Allow | Ok, 137/5.1G | Ok, 14/1.2G | No, 0/1.1G | Ok, 5/964M | No, 0/646M | No, 0/444M | Ok, 117/409M | No, 0/33M | Ok, 1/115M | No, 0/161M |
| Z6.1+WB+WC+WB | Allow | Ok, 37M/2.2G | Ok, 2.4M/392M | Ok, 960k/150M | Ok, 1.8M/228M | Ok, 1.6M/511M | Ok, 4.2M/336M | Ok, 25M/318M | Ok, 8.4k/33M | Ok, 1.1M/115M | Ok, 74k/161M |
| Z6.1+WB+WC+WC | Allow | Ok, 64k/5.1G | Ok, 5.8k/1.2G | Ok, 18k/1.1G | Ok, 4.9k/964M | Ok, 2.3k/646M | Ok, 3.5k/444M | Ok, 26k/409M | No, 0/33M | Ok, 2.3k/115M | Ok, 18/161M |
| Z6.1+WC+WB+UC | Allow | Ok, 138M/2.2G | Ok, 29M/392M | Ok, 10M/150M | Ok, 20M/228M | Ok, 13M/511M | Ok, 21M/336M | Ok, 41M/318M | Ok, 25/33M | Ok, 5.1M/115M | Ok, 1.9k/161M |
| Z6.1+WC+WB+WB | Allow | Ok, 50M/2.2G | Ok, 2.5M/392M | Ok, 3.7M/150M | Ok, 1.9M/228M | Ok, 3.0M/511M | Ok, 9.1M/336M | Ok, 28M/318M | Ok, 4.5k/33M | Ok, 1.7M/115M | Ok, 37k/161M |
| Z6.1+WC+WB+WC | Allow | Ok, 82M/2.2G | Ok, 17M/392M | Ok, 2.7M/150M | Ok, 12M/228M | Ok, 10M/511M | Ok, 10M/336M | Ok, 25M/318M | Ok, 8/33M | Ok, 4.4M/115M | Ok, 2.4k/161M |
| Z6.1+WC+WC+UC | Allow | Ok, 17M/2.2G | Ok, 4.0M/392M | Ok, 7.8M/150M | Ok, 1.8M/228M | Ok, 657k/511M | Ok, 1.3M/336M | Ok, 716k/318M | No, 0/33M | Ok, 279k/115M | Ok, 1/161M |
| Z6.1+WC+WC+WB | Allow | Ok, 75M/2.2G | Ok, 12M/392M | Ok, 909k/150M | Ok, 9.1M/228M | Ok, 8.6M/511M | Ok, 14M/336M | Ok, 27M/318M | Ok, 3.9k/33M | Ok, 3.8M/115M | Ok, 52k/161M |
| Z6.1+WC+WC+WC | Allow | Ok, 29M/2.2G | Ok, 4.8M/392M | Ok, 2.8M/150M | Ok, 2.9M/228M | Ok, 3.8M/511M | Ok, 8.6M/336M | Ok, 4.5M/318M | Ok, 3/33M | Ok, 1.7M/115M | Ok, 3/161M |
| Z6.2+WB+WC+UC | Allow | Ok, 355/5.1G | Ok, 1/1.2G | No, 0/1.1G | Ok, 1/964M | No, 0/646M | No, 0/444M | Ok, 344/409M | No, 0/33M | Ok, 9/115M | No, 0/161M |
| Z6.2+WB+WC+WB | Allow | Ok, 431/5.1G | Ok, 17/1.2G | No, 0/1.1G | Ok, 4/964M | No, 0/646M | Ok, 1/444M | Ok, 403/409M | No, 0/33M | Ok, 6/115M | No, 0/161M |
| Z6.2+WB+WC+WC | Allow | Ok, 8/5.1G | No, 0/1.2G | No, 0/1.1G | No, 0/964M | No, 0/646M | Ok, 2/444M | Ok, 4/409M | No, 0/33M | Ok, 2/115M | No, 0/161M |
| Allow unseen | Allow unseen | Allow unseen | Allow unseen | Allow unseen | Allow unseen | ||||||
| Z6.2+WC+WB+UC | Allow | Ok, 93M/2.2G | Ok, 18M/392M | Ok, 4.0M/150M | Ok, 13M/228M | Ok, 7.3M/511M | Ok, 9.3M/336M | Ok, 38M/318M | Ok, 162/33M | Ok, 4.4M/115M | Ok, 2.9k/161M |
| Z6.2+WC+WB+WB | Allow | Ok, 38M/2.2G | Ok, 1.9M/392M | Ok, 3.2M/150M | Ok, 1.3M/228M | Ok, 918k/511M | Ok, 4.4M/336M | Ok, 25M/318M | Ok, 5.6k/33M | Ok, 1.2M/115M | Ok, 68k/161M |
| Z6.2+WC+WB+WC | Allow | Ok, 71M/2.2G | Ok, 14M/392M | Ok, 3.2M/150M | Ok, 10M/228M | Ok, 6.1M/511M | Ok, 10M/336M | Ok, 23M/318M | Ok, 50/33M | Ok, 3.9M/115M | Ok, 638/161M |
| Z6.2+WC+WC+UC | Allow | Ok, 5.8M/2.2G | Ok, 634k/392M | Ok, 1.4M/150M | Ok, 435k/228M | Ok, 239k/511M | Ok, 1.8M/336M | Ok, 983k/318M | No, 0/33M | Ok, 319k/115M | Ok, 1/161M |
| Z6.2+WC+WC+WB | Allow | Ok, 69k/2.2G | Ok, 5.1k/392M | Ok, 13k/150M | Ok, 4.5k/228M | Ok, 5.6k/511M | Ok, 7.0k/336M | Ok, 29k/318M | No, 0/33M | Ok, 4.0k/115M | No, 0/161M |
| Z6.2+WC+WC+WC | Allow | Ok, 2.0M/2.2G | Ok, 132k/392M | Ok, 112k/150M | Ok, 136k/228M | Ok, 86k/511M | Ok, 482k/336M | Ok, 762k/318M | No, 0/33M | Ok, 333k/115M | No, 0/161M |
| Z6.3+UC+WB+WC | Allow | Ok, 389/5.1G | Ok, 3/1.2G | No, 0/1.1G | No, 0/964M | No, 0/646M | No, 0/444M | Ok, 382/409M | No, 0/33M | Ok, 4/115M | No, 0/161M |
| Z6.3+UC+WC+WB | Allow | Ok, 100M/2.2G | Ok, 14M/392M | Ok, 8.8M/150M | Ok, 11M/228M | Ok, 11M/511M | Ok, 17M/336M | Ok, 34M/318M | Ok, 87/33M | Ok, 4.4M/115M | Ok, 3.0k/161M |
| Z6.3+UC+WC+WC | Allow | Ok, 2.5M/2.2G | Ok, 93k/392M | Ok, 5.3k/150M | Ok, 98k/228M | Ok, 559k/511M | Ok, 1.2M/336M | Ok, 406k/318M | No, 0/33M | Ok, 141k/115M | Ok, 2/161M |
| Z6.3+WB+WB+WC | Allow | Ok, 832/5.1G | Ok, 117/1.2G | Ok, 10/1.1G | Ok, 55/964M | Ok, 2/646M | Ok, 6/444M | Ok, 611/409M | No, 0/33M | Ok, 31/115M | No, 0/161M |
| Z6.3+WB+WC+UC | Allow | Ok, 519/5.1G | Ok, 20/1.2G | Ok, 2/1.1G | Ok, 1/964M | No, 0/646M | No, 0/444M | Ok, 492/409M | No, 0/33M | Ok, 4/115M | No, 0/161M |
| Z6.3+WB+WC+WB | Allow | Ok, 48M/2.2G | Ok, 4.9M/392M | Ok, 1.2M/150M | Ok, 3.7M/228M | Ok, 3.3M/511M | Ok, 6.0M/336M | Ok, 27M/318M | Ok, 10k/33M | Ok, 1.4M/115M | Ok, 104k/161M |
| Z6.3+WB+WC+WC | Allow | Ok, 41k/2.2G | Ok, 3.8k/392M | Ok, 2.3k/150M | Ok, 7.0k/228M | Ok, 1.8k/511M | Ok, 4.1k/336M | Ok, 19k/318M | Ok, 2/33M | Ok, 3.3k/115M | Ok, 15/161M |
| Z6.3+WC+WB+UC | Allow | Ok, 131M/2.2G | Ok, 28M/392M | Ok, 10M/150M | Ok, 20M/228M | Ok, 11M/511M | Ok, 26M/336M | Ok, 33M/318M | Ok, 512/33M | Ok, 3.8M/115M | Ok, 7.7k/161M |
| Z6.3+WC+WB+WB | Allow | Ok, 54M/2.2G | Ok, 8.9M/392M | Ok, 1.6M/150M | Ok, 6.7M/228M | Ok, 3.5M/511M | Ok, 3.7M/336M | Ok, 27M/318M | Ok, 8.5k/33M | Ok, 2.4M/115M | Ok, 44k/161M |
| Z6.3+WC+WB+WC | Allow | Ok, 74M/2.2G | Ok, 16M/392M | Ok, 2.7M/150M | Ok, 11M/228M | Ok, 6.2M/511M | Ok, 12M/336M | Ok, 22M/318M | Ok, 132/33M | Ok, 3.8M/115M | Ok, 4.7k/161M |
| Z6.3+WC+WC+UC | Allow | Ok, 14M/2.2G | Ok, 4.3M/392M | Ok, 7.1M/150M | Ok, 2.2M/228M | Ok, 59k/511M | Ok, 12k/336M | Ok, 56k/318M | No, 0/33M | Ok, 29k/115M | Ok, 5/161M |
| Z6.3+WC+WC+WB | Allow | Ok, 122M/2.2G | Ok, 22M/392M | Ok, 8.3M/150M | Ok, 15M/228M | Ok, 13M/511M | Ok, 17M/336M | Ok, 41M/318M | Ok, 4.2k/33M | Ok, 5.7M/115M | Ok, 211k/161M |
| Z6.3+WC+WC+WC | Allow | Ok, 23M/2.2G | Ok, 4.3M/392M | Ok, 2.1M/150M | Ok, 2.5M/228M | Ok, 3.1M/511M | Ok, 6.0M/336M | Ok, 3.3M/318M | Ok, 40/33M | Ok, 1.5M/115M | Ok, 28/161M |
| Z6.4+UC+UC+WB | Allow | Ok, 620k/2.2G | Ok, 24k/392M | Ok, 10k/150M | Ok, 10k/228M | Ok, 74k/511M | Ok, 396k/336M | Ok, 91k/318M | No, 0/33M | Ok, 16k/115M | No, 0/161M |
| Z6.4+UC+WB+WB | Allow | Ok, 9.2k/5.1G | Ok, 60/1.2G | Ok, 1/1.1G | Ok, 128/964M | Ok, 99/646M | Ok, 553/444M | Ok, 7.9k/409M | No, 0/33M | Ok, 440/115M | Ok, 53/161M |
| Z6.4+UC+WC+WB | Allow | Ok, 117M/2.2G | Ok, 17M/392M | Ok, 10M/150M | Ok, 14M/228M | Ok, 15M/511M | Ok, 23M/336M | Ok, 35M/318M | Ok, 23/33M | Ok, 4.7M/115M | Ok, 7.4k/161M |
| Z6.4+WB+UC+UC | Allow | Ok, 1.8k/2.2G | Ok, 2/392M | Ok, 10/150M | Ok, 1/228M | Ok, 7/511M | Ok, 132/336M | Ok, 1.6k/318M | No, 0/33M | Ok, 76/115M | No, 0/161M |
| Z6.4+WB+UC+WB | Allow | Ok, 11M/2.2G | Ok, 567k/392M | Ok, 1.6M/150M | Ok, 815k/228M | Ok, 3.9M/511M | Ok, 3.2M/336M | Ok, 359k/318M | Ok, 3.2k/33M | Ok, 121k/115M | Ok, 596k/161M |
| Z6.4+WB+UC+WC | Allow | Ok, 100M/2.2G | Ok, 13M/392M | Ok, 9.3M/150M | Ok, 10M/228M | Ok, 6.8M/511M | Ok, 25M/336M | Ok, 31M/318M | Ok, 4/33M | Ok, 5.1M/115M | Ok, 7.1k/161M |
| Z6.4+WB+WB+UC | Allow | Ok, 909k/2.2G | Ok, 69k/392M | Ok, 173k/150M | Ok, 23k/228M | Ok, 191k/511M | Ok, 367k/336M | Ok, 35k/318M | No, 0/33M | Ok, 51k/115M | No, 0/161M |
| Z6.4+WB+WB+WB | Allow | Ok, 6.9M/2.2G | Ok, 495k/392M | Ok, 1.2M/150M | Ok, 634k/228M | Ok, 3.4M/511M | Ok, 393k/336M | Ok, 263k/318M | Ok, 2.5k/33M | Ok, 116k/115M | Ok, 370k/161M |
| Z6.4+WB+WB+WC | Allow | Ok, 55M/2.2G | Ok, 7.7M/392M | Ok, 2.2M/150M | Ok, 5.7M/228M | Ok, 7.4M/511M | Ok, 3.8M/336M | Ok, 26M/318M | Ok, 10k/33M | Ok, 2.2M/115M | Ok, 268k/161M |
| Z6.4+WB+WC+UC | Allow | Ok, 2.9k/2.2G | Ok, 64/392M | Ok, 29/150M | Ok, 15/228M | Ok, 16/511M | Ok, 500/336M | Ok, 1.6k/318M | No, 0/33M | Ok, 726/115M | No, 0/161M |
| Z6.4+WB+WC+WB | Allow | Ok, 107M/2.2G | Ok, 16M/392M | Ok, 6.5M/150M | Ok, 14M/228M | Ok, 15M/511M | Ok, 13M/336M | Ok, 35M/318M | Ok, 122k/33M | Ok, 4.1M/115M | Ok, 4.1M/161M |
| Z6.4+WB+WC+WC | Allow | Ok, 65M/2.2G | Ok, 8.2M/392M | Ok, 7.2M/150M | Ok, 5.8M/228M | Ok, 8.8M/511M | Ok, 13M/336M | Ok, 19M/318M | Ok, 153/33M | Ok, 4.0M/115M | Ok, 2.7k/161M |
| Z6.4+WC+UC+WB | Allow | Ok, 2.2k/2.2G | Ok, 17/392M | Ok, 15/150M | Ok, 9/228M | Ok, 4/511M | Ok, 123/336M | Ok, 1.8k/318M | No, 0/33M | Ok, 246/115M | No, 0/161M |
| Z6.4+WC+WB+UC | Allow | Ok, 104M/2.2G | Ok, 15M/392M | Ok, 10M/150M | Ok, 10M/228M | Ok, 12M/511M | Ok, 24M/336M | Ok, 28M/318M | Ok, 166/33M | Ok, 4.2M/115M | Ok, 2.1k/161M |
| Z6.4+WC+WB+WB | Allow | Ok, 92M/2.2G | Ok, 16M/392M | Ok, 4.3M/150M | Ok, 13M/228M | Ok, 14M/511M | Ok, 5.6M/336M | Ok, 33M/318M | Ok, 41k/33M | Ok, 5.3M/115M | Ok, 398k/161M |
| Z6.4+WC+WB+WC | Allow | Ok, 107M/2.2G | Ok, 15M/392M | Ok, 11M/150M | Ok, 11M/228M | Ok, 13M/511M | Ok, 24M/336M | Ok, 28M/318M | Ok, 98/33M | Ok, 4.3M/115M | Ok, 2.4k/161M |
| Z6.4+WC+WC+UC | Allow | Ok, 2.7M/2.2G | Ok, 976k/392M | Ok, 1.2M/150M | Ok, 456k/228M | Ok, 16k/511M | Ok, 19k/336M | Ok, 63k/318M | No, 0/33M | Ok, 28k/115M | Ok, 2/161M |
| Z6.4+WC+WC+WB | Allow | Ok, 143M/2.2G | Ok, 23M/392M | Ok, 10M/150M | Ok, 16M/228M | Ok, 19M/511M | Ok, 24M/336M | Ok, 44M/318M | Ok, 8.6k/33M | Ok, 6.3M/115M | Ok, 357k/161M |
| Z6.4+WC+WC+WC | Allow | Ok, 3.3M/2.2G | Ok, 1.0M/392M | Ok, 1.6M/150M | Ok, 510k/228M | Ok, 13k/511M | Ok, 20k/336M | Ok, 73k/318M | No, 0/33M | Ok, 29k/115M | Ok, 2/161M |
| Z6.5+UC+WB+WC | Allow | Ok, 111/5.1G | Ok, 11/1.2G | No, 0/1.1G | Ok, 6/964M | No, 0/646M | Ok, 4/444M | Ok, 89/409M | No, 0/33M | Ok, 1/115M | No, 0/161M |
| Z6.5+UC+WC+WB | Allow | Ok, 107M/2.2G | Ok, 14M/392M | Ok, 7.8M/150M | Ok, 11M/228M | Ok, 15M/511M | Ok, 20M/336M | Ok, 34M/318M | Ok, 1/33M | Ok, 4.6M/115M | Ok, 2.4k/161M |
| Z6.5+UC+WC+WC | Allow | Ok, 1.7M/2.2G | Ok, 680k/392M | Ok, 10k/150M | Ok, 401k/228M | Ok, 30k/511M | Ok, 229k/336M | Ok, 219k/318M | No, 0/33M | Ok, 142k/115M | No, 0/161M |
| Z6.5+WB+UC+UC | Allow | Ok, 846k/2.2G | Ok, 6.0k/392M | Ok, 36k/150M | Ok, 4.2k/228M | Ok, 259k/511M | Ok, 342k/336M | Ok, 176k/318M | No, 0/33M | Ok, 23k/115M | No, 0/161M |
| Z6.5+WB+UC+WB | Allow | Ok, 12k/2.2G | Ok, 68/392M | Ok, 66/150M | Ok, 59/228M | Ok, 115/511M | Ok, 2.2k/336M | Ok, 10k/318M | No, 0/33M | Ok, 144/115M | Ok, 3/161M |
| Z6.5+WB+UC+WC | Allow | Ok, 126M/2.2G | Ok, 18M/392M | Ok, 15M/150M | Ok, 14M/228M | Ok, 12M/511M | Ok, 20M/336M | Ok, 40M/318M | Ok, 6/33M | Ok, 6.3M/115M | Ok, 10k/161M |
| Z6.5+WB+WB+UC | Allow | Ok, 2.4M/2.2G | Ok, 47k/392M | Ok, 42k/150M | Ok, 30k/228M | Ok, 541k/511M | Ok, 1.4M/336M | Ok, 104k/318M | No, 0/33M | Ok, 229k/115M | Ok, 491/161M |
| Z6.5+WB+WB+WB | Allow | Ok, 208k/2.2G | Ok, 14k/392M | Ok, 10k/150M | Ok, 12k/228M | Ok, 69k/511M | Ok, 39k/336M | Ok, 47k/318M | Ok, 25/33M | Ok, 6.8k/115M | Ok, 10k/161M |
| Z6.5+WB+WB+WC | Allow | Ok, 54M/2.2G | Ok, 2.3M/392M | Ok, 4.5M/150M | Ok, 1.9M/228M | Ok, 8.1M/511M | Ok, 7.9M/336M | Ok, 26M/318M | Ok, 21k/33M | Ok, 2.3M/115M | Ok, 386k/161M |
| Z6.5+WB+WC+UC | Allow | Ok, 10k/2.2G | Ok, 752/392M | Ok, 340/150M | Ok, 463/228M | Ok, 212/511M | Ok, 1.2k/336M | Ok, 4.2k/318M | No, 0/33M | Ok, 2.7k/115M | Ok, 1/161M |
| Z6.5+WB+WC+WB | Allow | Ok, 89M/2.2G | Ok, 13M/392M | Ok, 6.1M/150M | Ok, 12M/228M | Ok, 9.1M/511M | Ok, 11M/336M | Ok, 33M/318M | Ok, 78k/33M | Ok, 3.2M/115M | Ok, 1.9M/161M |
| Z6.5+WB+WC+WC | Allow | Ok, 90M/2.2G | Ok, 13M/392M | Ok, 4.4M/150M | Ok, 11M/228M | Ok, 10M/511M | Ok, 13M/336M | Ok, 31M/318M | Ok, 21k/33M | Ok, 5.6M/115M | Ok, 428k/161M |
| Z6.5+WC+WB+UC | Allow | Ok, 123M/2.2G | Ok, 18M/392M | Ok, 5.9M/150M | Ok, 13M/228M | Ok, 13M/511M | Ok, 32M/336M | Ok, 36M/318M | Ok, 178/33M | Ok, 5.0M/115M | Ok, 1.9k/161M |
| Z6.5+WC+WB+WB | Allow | Ok, 57M/2.2G | Ok, 9.5M/392M | Ok, 1.8M/150M | Ok, 7.2M/228M | Ok, 4.0M/511M | Ok, 4.1M/336M | Ok, 27M/318M | Ok, 6.6k/33M | Ok, 2.6M/115M | Ok, 42k/161M |
| Z6.5+WC+WB+WC | Allow | Ok, 61M/2.2G | Ok, 11M/392M | Ok, 2.5M/150M | Ok, 8.0M/228M | Ok, 7.6M/511M | Ok, 13M/336M | Ok, 15M/318M | Ok, 26/33M | Ok, 4.0M/115M | Ok, 662/161M |
| Z6.5+WC+WC+UC | Allow | Ok, 10M/2.2G | Ok, 2.5M/392M | Ok, 5.7M/150M | Ok, 1.3M/228M | Ok, 125k/511M | Ok, 23k/336M | Ok, 96k/318M | No, 0/33M | Ok, 115k/115M | Ok, 1/161M |
| Z6.5+WC+WC+WB | Allow | Ok, 131M/2.2G | Ok, 22M/392M | Ok, 10M/150M | Ok, 16M/228M | Ok, 15M/511M | Ok, 20M/336M | Ok, 42M/318M | Ok, 6.5k/33M | Ok, 5.9M/115M | Ok, 87k/161M |
| Z6.5+WC+WC+WC | Allow | Ok, 22M/2.2G | Ok, 4.0M/392M | Ok, 2.3M/150M | Ok, 2.2M/228M | Ok, 3.3M/511M | Ok, 6.7M/336M | Ok, 2.0M/318M | No, 0/33M | Ok, 1.2M/115M | Ok, 5/161M |
| Allow unseen |
In SC violations, we replace one write per thread by atomic-exchange. This should and does restore SC.
| 2+2W+ponaas+WB+WC | Forbid | Ok, 0/2.8G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | Ok, 0/863M | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/309M |
| 2+2W+ponaa+poana+WB+WC | Forbid | Ok, 0/2.8G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | Ok, 0/863M | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/309M |
| 2+2W+ponaas+WC+WC | Forbid | Ok, 0/2.8G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | Ok, 0/863M | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/309M |
| 2+2W+ponaa+poana+WC+WC | Forbid | Ok, 0/2.8G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | Ok, 0/863M | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/309M |
| SB+poanas+UC+WT | Forbid | Ok, 0/1.9G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | — | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/269M |
| SB+poanas+WB+UC | Forbid | Ok, 0/2.8G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | Ok, 0/863M | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/269M |
| SB+poanas+WB+WB | Forbid | Ok, 0/2.8G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | Ok, 0/863M | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/269M |
| SB+poanas+WB+WC | Forbid | Ok, 0/2.8G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | Ok, 0/863M | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/269M |
| SB+poanas+WB+WT | Forbid | Ok, 0/1.9G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | — | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/269M |
| SB+poanas+WC+WT | Forbid | Ok, 0/1.9G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | — | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/269M |
| SB+poanas+WT+WT | Forbid | Ok, 0/1.9G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | — | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/269M |
| MP+ponaa+po+WB+WC | Forbid | Ok, 0/2.8G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | Ok, 0/863M | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/267M |
| MP+poana+po+WB+WC | Forbid | Ok, 0/2.8G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | Ok, 0/863M | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/267M |
| MP+ponaa+po+WC+WB | Forbid | Ok, 0/2.8G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | Ok, 0/863M | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/267M |
| MP+poana+po+WC+WB | Forbid | Ok, 0/2.8G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | Ok, 0/863M | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/267M |
| MP+ponaa+po+WC+WC | Forbid | Ok, 0/2.8G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | Ok, 0/863M | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/267M |
| MP+poana+po+WC+WC | Forbid | Ok, 0/2.8G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | Ok, 0/863M | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/267M |
| R+ponaa+poana+WB+UC | Forbid | Ok, 0/2.8G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | Ok, 0/863M | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/309M |
| R+poanas+WB+UC | Forbid | Ok, 0/2.8G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | Ok, 0/863M | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/309M |
| R+ponaa+poana+WB+WB | Forbid | Ok, 0/2.8G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | Ok, 0/863M | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/309M |
| R+poanas+WB+WB | Forbid | Ok, 0/2.8G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | Ok, 0/863M | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/309M |
| R+ponaa+poana+WB+WC | Forbid | Ok, 0/2.8G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | Ok, 0/863M | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/309M |
| R+poanas+WB+WC | Forbid | Ok, 0/2.8G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | Ok, 0/863M | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/309M |
| R+ponaa+poana+WB+WT | Forbid | Ok, 0/2.0G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | — | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/309M |
| R+poanas+WB+WT | Forbid | Ok, 0/2.0G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | — | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/309M |
| R+ponaa+poana+WC+WB | Forbid | Ok, 0/2.8G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | Ok, 0/863M | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/309M |
| R+poanas+WC+WB | Forbid | Ok, 0/2.8G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | Ok, 0/863M | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/309M |
| R+ponaa+poana+WC+WC | Forbid | Ok, 0/2.8G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | Ok, 0/863M | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/309M |
| R+poanas+WC+WC | Forbid | Ok, 0/2.8G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | Ok, 0/863M | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/309M |
| R+ponaa+poana+WT+UC | Forbid | Ok, 0/2.0G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | — | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/309M |
| R+poanas+WT+UC | Forbid | Ok, 0/2.0G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | — | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/309M |
| R+ponaa+poana+WT+WB | Forbid | Ok, 0/2.0G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | — | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/309M |
| R+poanas+WT+WB | Forbid | Ok, 0/2.0G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | — | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/309M |
| R+ponaa+poana+WT+WC | Forbid | Ok, 0/2.0G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | — | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/309M |
| R+poanas+WT+WC | Forbid | Ok, 0/2.0G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | — | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/309M |
| R+ponaa+poana+WT+WT | Forbid | Ok, 0/2.0G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | — | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/309M |
| R+poanas+WT+WT | Forbid | Ok, 0/2.0G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | — | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/309M |
| S+ponaa+po+WB+WC | Forbid | Ok, 0/2.8G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | Ok, 0/863M | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/269M |
| S+poana+po+WB+WC | Forbid | Ok, 0/2.8G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | Ok, 0/863M | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/269M |
| S+ponaa+po+WC+WB | Forbid | Ok, 0/2.8G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | Ok, 0/863M | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/269M |
| S+poana+po+WC+WB | Forbid | Ok, 0/2.8G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | Ok, 0/863M | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/269M |
| S+ponaa+po+WC+WC | Forbid | Ok, 0/2.8G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | Ok, 0/863M | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/269M |
| S+poana+po+WC+WC | Forbid | Ok, 0/2.8G | Ok, 0/586M | Ok, 0/120M | Ok, 0/304M | Ok, 0/863M | Ok, 0/172M | Ok, 0/237M | Ok, 0/66M | Ok, 0/173M | Ok, 0/269M |
| RWC+po+poana+WB+UC | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| RWC+po+poana+WB+WB | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| RWC+po+poana+WB+WC | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| WRR+2W+po+poana+WB+WC | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| WRR+2W+po+poana+WC+WB | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| WRR+2W+po+poana+WC+WC | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| WRR+2W+po+ponaa+WB+WC | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| WRR+2W+po+ponaa+WC+WB | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| WRR+2W+po+ponaa+WC+WC | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| WRW+2W+po+poana+WB+WC | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| WRW+2W+po+poana+WC+WB | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| WRW+2W+po+poana+WC+WC | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| WRW+2W+po+ponaa+WB+WC | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| WRW+2W+po+ponaa+WC+WB | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| WRW+2W+po+ponaa+WC+WC | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| WRW+WR+po+poana+WB+UC | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| WRW+WR+po+poana+WB+WB | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| WRW+WR+po+poana+WB+WC | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| 3.2W+poanas+WB+WB+WC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.2W+ponaas+WB+WB+WC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.2W+ponaa+poana+poana+WB+WB+WC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.2W+ponaa+ponaa+poana+WB+WB+WC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.2W+poanas+WB+WC+UC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.2W+ponaas+WB+WC+UC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.2W+ponaa+poana+poana+WB+WC+UC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.2W+ponaa+ponaa+poana+WB+WC+UC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.2W+poanas+WB+WC+WC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.2W+ponaas+WB+WC+WC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.2W+ponaa+poana+poana+WB+WC+WC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.2W+ponaa+ponaa+poana+WB+WC+WC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.2W+poanas+WC+WC+UC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.2W+ponaas+WC+WC+UC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.2W+ponaa+poana+poana+WC+WC+UC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.2W+ponaa+ponaa+poana+WC+WC+UC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.2W+poanas+WC+WC+WC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.2W+ponaas+WC+WC+WC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.2W+ponaa+poana+poana+WC+WC+WC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.2W+ponaa+ponaa+poana+WC+WC+WC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.SB+poanas+WB+UC+UC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.SB+poanas+WB+WB+UC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.SB+poanas+WB+WB+WB | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.SB+poanas+WB+WB+WC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.SB+poanas+WB+WC+UC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.SB+poanas+WB+WC+WC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| ISA2+ponaa+po+po+WB+WC+UC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| ISA2+poana+po+po+WB+WC+UC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| ISA2+ponaa+po+po+WB+WC+WB | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| ISA2+poana+po+po+WB+WC+WB | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| ISA2+ponaa+po+po+WB+WC+WC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| ISA2+poana+po+po+WB+WC+WC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| ISA2+ponaa+po+po+WC+WB+UC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| ISA2+poana+po+po+WC+WB+UC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| ISA2+ponaa+po+po+WC+WB+WB | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| ISA2+poana+po+po+WC+WB+WB | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| ISA2+ponaa+po+po+WC+WB+WC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| ISA2+poana+po+po+WC+WB+WC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| ISA2+ponaa+po+po+WC+WC+UC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| ISA2+poana+po+po+WC+WC+UC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| ISA2+ponaa+po+po+WC+WC+WB | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| ISA2+poana+po+po+WC+WC+WB | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| ISA2+ponaa+po+po+WC+WC+WC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| ISA2+poana+po+po+WC+WC+WC | Forbid | Ok, 0/1.6G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| W+RWC+ponaa+po+poana+WB+UC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+poana+po+poana+WB+UC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+ponaa+po+poana+WB+UC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+poana+po+poana+WB+UC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+ponaa+po+poana+WB+UC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+poana+po+poana+WB+UC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+ponaa+po+poana+WB+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+poana+po+poana+WB+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+ponaa+po+poana+WB+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+poana+po+poana+WB+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+ponaa+po+poana+WB+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+poana+po+poana+WB+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+ponaa+po+poana+WB+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+poana+po+poana+WB+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+ponaa+po+poana+WB+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+poana+po+poana+WB+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+ponaa+po+poana+WB+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+poana+po+poana+WB+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+ponaa+po+poana+WC+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+poana+po+poana+WC+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+ponaa+po+poana+WC+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+poana+po+poana+WC+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+ponaa+po+poana+WC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+poana+po+poana+WC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+ponaa+po+poana+WC+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+poana+po+poana+WC+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+ponaa+po+poana+WC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+poana+po+poana+WC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+ponaa+po+poana+WC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+poana+po+poana+WC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+poana+po+poana+WB+UC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+ponaa+po+poana+WB+UC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+poana+po+poana+WB+UC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+ponaa+po+poana+WB+UC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+poana+po+poana+WB+UC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+ponaa+po+poana+WB+UC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+poana+po+poana+WB+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+ponaa+po+poana+WB+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+poana+po+poana+WB+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+ponaa+po+poana+WB+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+poana+po+poana+WB+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+ponaa+po+poana+WB+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+poana+po+poana+WB+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+ponaa+po+poana+WB+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+poana+po+poana+WB+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+ponaa+po+poana+WB+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+poana+po+poana+WB+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+ponaa+po+poana+WB+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+poana+po+poana+WC+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+ponaa+po+poana+WC+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+poana+po+poana+WC+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+ponaa+po+poana+WC+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+poana+po+poana+WC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+ponaa+po+poana+WC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+poana+po+poana+WC+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+ponaa+po+poana+WC+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+poana+po+poana+WC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+ponaa+po+poana+WC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+poana+po+poana+WC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+ponaa+po+poana+WC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+poana+poana+po+UC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+poana+ponaa+po+UC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+ponaa+poana+po+UC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+ponaa+ponaa+po+UC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+poana+poana+po+UC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+poana+ponaa+po+UC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+ponaa+poana+po+UC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+ponaa+ponaa+po+UC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+poana+poana+po+UC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+poana+ponaa+po+UC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+ponaa+poana+po+UC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+ponaa+ponaa+po+UC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+poana+poana+po+WB+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+poana+ponaa+po+WB+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+ponaa+poana+po+WB+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+ponaa+ponaa+po+WB+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+poana+poana+po+WB+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+poana+ponaa+po+WB+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+ponaa+poana+po+WB+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+ponaa+ponaa+po+WB+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+poana+poana+po+WB+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+poana+ponaa+po+WB+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+ponaa+poana+po+WB+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+ponaa+ponaa+po+WB+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+poana+poana+po+WB+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+poana+ponaa+po+WB+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+ponaa+poana+po+WB+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+ponaa+ponaa+po+WB+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+poana+poana+po+WC+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+poana+ponaa+po+WC+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+ponaa+poana+po+WC+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+ponaa+ponaa+po+WC+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+poana+poana+po+WC+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+poana+ponaa+po+WC+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+ponaa+poana+po+WC+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+ponaa+ponaa+po+WC+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+poana+poana+po+WC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+poana+ponaa+po+WC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+ponaa+poana+po+WC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+ponaa+ponaa+po+WC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+poana+poana+po+WC+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+poana+ponaa+po+WC+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+ponaa+poana+po+WC+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+ponaa+ponaa+po+WC+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+poana+poana+po+WC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+poana+ponaa+po+WC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+ponaa+poana+po+WC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+ponaa+ponaa+po+WC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+poana+poana+po+WC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+poana+ponaa+po+WC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+ponaa+poana+po+WC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+ponaa+ponaa+po+WC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.2+poana+po+po+WB+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.2+ponaa+po+po+WB+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.2+poana+po+po+WB+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.2+ponaa+po+po+WB+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.2+poana+po+po+WB+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.2+ponaa+po+po+WB+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.2+poana+po+po+WC+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.2+ponaa+po+po+WC+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.2+poana+po+po+WC+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.2+ponaa+po+po+WC+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.2+poana+po+po+WC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.2+ponaa+po+po+WC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.2+poana+po+po+WC+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.2+ponaa+po+po+WC+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.2+poana+po+po+WC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.2+ponaa+po+po+WC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.2+poana+po+po+WC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.2+ponaa+po+po+WC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+poana+poana+po+UC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+poana+ponaa+po+UC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+ponaa+poana+po+UC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+ponaa+ponaa+po+UC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+poana+poana+po+UC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+poana+ponaa+po+UC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+ponaa+poana+po+UC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+ponaa+ponaa+po+UC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+poana+poana+po+UC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+poana+ponaa+po+UC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+ponaa+poana+po+UC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+ponaa+ponaa+po+UC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+poana+poana+po+WB+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+poana+ponaa+po+WB+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+ponaa+poana+po+WB+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+ponaa+ponaa+po+WB+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+poana+poana+po+WB+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+poana+ponaa+po+WB+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+ponaa+poana+po+WB+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+ponaa+ponaa+po+WB+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+poana+poana+po+WB+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+poana+ponaa+po+WB+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+ponaa+poana+po+WB+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+ponaa+ponaa+po+WB+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+poana+poana+po+WB+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+poana+ponaa+po+WB+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+ponaa+poana+po+WB+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+ponaa+ponaa+po+WB+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+poana+poana+po+WC+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+poana+ponaa+po+WC+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+ponaa+poana+po+WC+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+ponaa+ponaa+po+WC+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+poana+poana+po+WC+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+poana+ponaa+po+WC+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+ponaa+poana+po+WC+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+ponaa+ponaa+po+WC+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+poana+poana+po+WC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+poana+ponaa+po+WC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+ponaa+poana+po+WC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+ponaa+ponaa+po+WC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+poana+poana+po+WC+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+poana+ponaa+po+WC+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+ponaa+poana+po+WC+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+ponaa+ponaa+po+WC+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+poana+poana+po+WC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+poana+ponaa+po+WC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+ponaa+poana+po+WC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+ponaa+ponaa+po+WC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+poana+poana+po+WC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+poana+ponaa+po+WC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+ponaa+poana+po+WC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+ponaa+ponaa+po+WC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+poanas+UC+UC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+ponaa+poana+poana+UC+UC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+poanas+UC+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+ponaa+poana+poana+UC+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+poanas+UC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+ponaa+poana+poana+UC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+poanas+WB+UC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+ponaa+poana+poana+WB+UC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+poanas+WB+UC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+ponaa+poana+poana+WB+UC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+poanas+WB+UC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+ponaa+poana+poana+WB+UC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+poanas+WB+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+ponaa+poana+poana+WB+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+poanas+WB+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+ponaa+poana+poana+WB+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+poanas+WB+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+ponaa+poana+poana+WB+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+poanas+WB+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+ponaa+poana+poana+WB+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+poanas+WB+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+ponaa+poana+poana+WB+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+poanas+WB+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+ponaa+poana+poana+WB+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+poanas+WC+UC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+ponaa+poana+poana+WC+UC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+poanas+WC+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+ponaa+poana+poana+WC+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+poanas+WC+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+ponaa+poana+poana+WC+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+poanas+WC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+ponaa+poana+poana+WC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+poanas+WC+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+ponaa+poana+poana+WC+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+poanas+WC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+ponaa+poana+poana+WC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+poanas+WC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+ponaa+poana+poana+WC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poana+ponaa+poana+UC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poanas+UC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+poana+poana+UC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+ponaa+poana+UC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poana+ponaa+poana+UC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poanas+UC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+poana+poana+UC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+ponaa+poana+UC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poana+ponaa+poana+UC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poanas+UC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+poana+poana+UC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+ponaa+poana+UC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poana+ponaa+poana+WB+UC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poanas+WB+UC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+poana+poana+WB+UC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+ponaa+poana+WB+UC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poana+ponaa+poana+WB+UC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poanas+WB+UC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+poana+poana+WB+UC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+ponaa+poana+WB+UC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poana+ponaa+poana+WB+UC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poanas+WB+UC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+poana+poana+WB+UC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+ponaa+poana+WB+UC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poana+ponaa+poana+WB+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poanas+WB+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+poana+poana+WB+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+ponaa+poana+WB+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poana+ponaa+poana+WB+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poanas+WB+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+poana+poana+WB+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+ponaa+poana+WB+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poana+ponaa+poana+WB+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poanas+WB+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+poana+poana+WB+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+ponaa+poana+WB+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poana+ponaa+poana+WB+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poanas+WB+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+poana+poana+WB+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+ponaa+poana+WB+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poana+ponaa+poana+WB+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poanas+WB+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+poana+poana+WB+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+ponaa+poana+WB+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poana+ponaa+poana+WB+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poanas+WB+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+poana+poana+WB+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+ponaa+poana+WB+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poana+ponaa+poana+WC+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poanas+WC+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+poana+poana+WC+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+ponaa+poana+WC+WB+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poana+ponaa+poana+WC+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poanas+WC+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+poana+poana+WC+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+ponaa+poana+WC+WB+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poana+ponaa+poana+WC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poanas+WC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+poana+poana+WC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+ponaa+poana+WC+WB+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poana+ponaa+poana+WC+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poanas+WC+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+poana+poana+WC+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+ponaa+poana+WC+WC+UC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poana+ponaa+poana+WC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poanas+WC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+poana+poana+WC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+ponaa+poana+WC+WC+WB | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poana+ponaa+poana+WC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+poanas+WC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+poana+poana+WC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+ponaa+ponaa+poana+WC+WC+WC | Forbid | Ok, 0/1.5G | Ok, 0/300M | Ok, 0/60M | Ok, 0/160M | Ok, 0/447M | Ok, 0/115M | Ok, 0/158M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
In SC violations, we insert mfence in-between write-to-read pairs and sfence in-between write-to-write pairs. This should and does restore SC.
| Model | Hardware | CoreI5 | CoreI5-dual | CoreI7 | Chianti | Limoux | Teraram | Estephe | Barsac | Zdani | |
| 2+2W+sfences+WB+WC | Forbid | Ok, 0/3.3G | Ok, 0/842M | Ok, 0/88M | Ok, 0/240M | Ok, 0/1.1G | Ok, 0/228M | Ok, 0/327M | Ok, 0/66M | Ok, 0/173M | Ok, 0/267M |
| 2+2W+sfences+WC+WC | Forbid | Ok, 0/3.3G | Ok, 0/842M | Ok, 0/88M | Ok, 0/240M | Ok, 0/1.1G | Ok, 0/228M | Ok, 0/327M | Ok, 0/66M | Ok, 0/173M | Ok, 0/267M |
| MP+sfence+po+WB+WC | Forbid | Ok, 0/3.3G | Ok, 0/842M | Ok, 0/88M | Ok, 0/240M | Ok, 0/1.1G | Ok, 0/228M | Ok, 0/327M | Ok, 0/66M | Ok, 0/173M | Ok, 0/267M |
| MP+sfence+po+WC+WB | Forbid | Ok, 0/3.3G | Ok, 0/842M | Ok, 0/88M | Ok, 0/240M | Ok, 0/1.1G | Ok, 0/228M | Ok, 0/327M | Ok, 0/66M | Ok, 0/173M | Ok, 0/267M |
| MP+sfence+po+WC+WC | Forbid | Ok, 0/3.3G | Ok, 0/842M | Ok, 0/88M | Ok, 0/240M | Ok, 0/1.1G | Ok, 0/228M | Ok, 0/327M | Ok, 0/66M | Ok, 0/173M | Ok, 0/267M |
| R+sfence+mfence+WB+UC | Forbid | Ok, 0/3.3G | Ok, 0/842M | Ok, 0/88M | Ok, 0/240M | Ok, 0/1.1G | Ok, 0/228M | Ok, 0/327M | Ok, 0/66M | Ok, 0/173M | Ok, 0/267M |
| R+sfence+mfence+WB+WB | Forbid | Ok, 0/3.3G | Ok, 0/842M | Ok, 0/88M | Ok, 0/240M | Ok, 0/1.1G | Ok, 0/228M | Ok, 0/327M | Ok, 0/66M | Ok, 0/173M | Ok, 0/267M |
| R+sfence+mfence+WB+WC | Forbid | Ok, 0/3.3G | Ok, 0/842M | Ok, 0/88M | Ok, 0/240M | Ok, 0/1.1G | Ok, 0/228M | Ok, 0/327M | Ok, 0/66M | Ok, 0/173M | Ok, 0/267M |
| R+sfence+mfence+WB+WT | Forbid | Ok, 0/2.2G | Ok, 0/842M | Ok, 0/88M | Ok, 0/240M | — | Ok, 0/228M | Ok, 0/327M | Ok, 0/66M | Ok, 0/173M | Ok, 0/267M |
| R+sfence+mfence+WC+WB | Forbid | Ok, 0/3.3G | Ok, 0/842M | Ok, 0/88M | Ok, 0/240M | Ok, 0/1.1G | Ok, 0/228M | Ok, 0/327M | Ok, 0/66M | Ok, 0/173M | Ok, 0/267M |
| R+sfence+mfence+WC+WC | Forbid | Ok, 0/3.3G | Ok, 0/842M | Ok, 0/88M | Ok, 0/240M | Ok, 0/1.1G | Ok, 0/228M | Ok, 0/327M | Ok, 0/66M | Ok, 0/173M | Ok, 0/267M |
| R+sfence+mfence+WT+UC | Forbid | Ok, 0/2.2G | Ok, 0/842M | Ok, 0/88M | Ok, 0/240M | — | Ok, 0/228M | Ok, 0/327M | Ok, 0/66M | Ok, 0/173M | Ok, 0/267M |
| R+sfence+mfence+WT+WB | Forbid | Ok, 0/2.2G | Ok, 0/842M | Ok, 0/88M | Ok, 0/240M | — | Ok, 0/228M | Ok, 0/327M | Ok, 0/66M | Ok, 0/173M | Ok, 0/267M |
| R+sfence+mfence+WT+WC | Forbid | Ok, 0/2.2G | Ok, 0/842M | Ok, 0/88M | Ok, 0/240M | — | Ok, 0/228M | Ok, 0/327M | Ok, 0/66M | Ok, 0/173M | Ok, 0/267M |
| R+sfence+mfence+WT+WT | Forbid | Ok, 0/2.2G | Ok, 0/842M | Ok, 0/88M | Ok, 0/240M | — | Ok, 0/228M | Ok, 0/327M | Ok, 0/66M | Ok, 0/173M | Ok, 0/267M |
| S+sfence+po+WB+WC | Forbid | Ok, 0/3.3G | Ok, 0/842M | Ok, 0/88M | Ok, 0/240M | Ok, 0/1.1G | Ok, 0/228M | Ok, 0/327M | Ok, 0/66M | Ok, 0/173M | Ok, 0/227M |
| S+sfence+po+WC+WB | Forbid | Ok, 0/3.3G | Ok, 0/842M | Ok, 0/88M | Ok, 0/240M | Ok, 0/1.1G | Ok, 0/228M | Ok, 0/327M | Ok, 0/66M | Ok, 0/173M | Ok, 0/227M |
| S+sfence+po+WC+WC | Forbid | Ok, 0/3.3G | Ok, 0/842M | Ok, 0/88M | Ok, 0/240M | Ok, 0/1.1G | Ok, 0/228M | Ok, 0/327M | Ok, 0/66M | Ok, 0/173M | Ok, 0/227M |
| SB+mfences+UC+WT | Forbid | Ok, 0/3.7G | Ok, 0/1.1G | Ok, 0/236M | Ok, 0/584M | — | Ok, 0/564M | Ok, 0/688M | Ok, 0/66M | Ok, 0/173M | Ok, 0/227M |
| SB+mfences+WB+UC | Forbid | Ok, 0/4.9G | Ok, 0/1.1G | Ok, 0/236M | Ok, 0/584M | Ok, 0/1.2G | Ok, 0/564M | Ok, 0/688M | Ok, 0/66M | Ok, 0/173M | Ok, 0/227M |
| SB+mfences+WB+WB | Forbid | Ok, 0/4.9G | Ok, 0/1.1G | Ok, 0/236M | Ok, 0/584M | Ok, 0/1.2G | Ok, 0/564M | Ok, 0/688M | Ok, 0/66M | Ok, 0/173M | Ok, 0/227M |
| SB+mfences+WB+WC | Forbid | Ok, 0/4.9G | Ok, 0/1.1G | Ok, 0/236M | Ok, 0/584M | Ok, 0/1.2G | Ok, 0/564M | Ok, 0/688M | Ok, 0/66M | Ok, 0/173M | Ok, 0/227M |
| SB+mfences+WB+WT | Forbid | Ok, 0/3.7G | Ok, 0/1.1G | Ok, 0/236M | Ok, 0/584M | — | Ok, 0/564M | Ok, 0/688M | Ok, 0/66M | Ok, 0/173M | Ok, 0/227M |
| SB+mfences+WC+WT | Forbid | Ok, 0/3.7G | Ok, 0/1.1G | Ok, 0/236M | Ok, 0/584M | — | Ok, 0/564M | Ok, 0/688M | Ok, 0/66M | Ok, 0/173M | Ok, 0/227M |
| SB+mfences+WT+WT | Forbid | Ok, 0/3.7G | Ok, 0/1.1G | Ok, 0/236M | Ok, 0/584M | — | Ok, 0/564M | Ok, 0/688M | Ok, 0/66M | Ok, 0/173M | Ok, 0/227M |
| RWC+po+mfence+WB+UC | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| RWC+po+mfence+WB+WB | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| RWC+po+mfence+WB+WC | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| WRR+2W+po+sfence+WB+WC | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| WRR+2W+po+sfence+WC+WB | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| WRR+2W+po+sfence+WC+WC | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| WRW+2W+po+sfence+WB+WC | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| WRW+2W+po+sfence+WC+WB | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| WRW+2W+po+sfence+WC+WC | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| WRW+WR+po+mfence+WB+UC | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| WRW+WR+po+mfence+WB+WB | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| WRW+WR+po+mfence+WB+WC | Forbid | Ok, 0/3.6G | Ok, 0/896M | Ok, 0/828M | Ok, 0/672M | Ok, 0/524M | Ok, 0/142M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| 3.2W+sfences+WB+WB+WC | Forbid | Ok, 0/1.9G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.2W+sfences+WB+WC+UC | Forbid | Ok, 0/1.9G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.2W+sfences+WB+WC+WC | Forbid | Ok, 0/1.9G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.2W+sfences+WC+WC+UC | Forbid | Ok, 0/1.9G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.2W+sfences+WC+WC+WC | Forbid | Ok, 0/1.9G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.SB+mfences+WB+UC+UC | Forbid | Ok, 0/1.9G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.SB+mfences+WB+WB+UC | Forbid | Ok, 0/1.9G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.SB+mfences+WB+WB+WB | Forbid | Ok, 0/1.9G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.SB+mfences+WB+WB+WC | Forbid | Ok, 0/1.9G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.SB+mfences+WB+WC+UC | Forbid | Ok, 0/1.9G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| 3.SB+mfences+WB+WC+WC | Forbid | Ok, 0/1.9G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| ISA2+sfence+po+po+WB+WC+UC | Forbid | Ok, 0/1.9G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| ISA2+sfence+po+po+WB+WC+WB | Forbid | Ok, 0/1.9G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| ISA2+sfence+po+po+WB+WC+WC | Forbid | Ok, 0/1.9G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| ISA2+sfence+po+po+WC+WB+UC | Forbid | Ok, 0/1.9G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| ISA2+sfence+po+po+WC+WB+WB | Forbid | Ok, 0/1.9G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| ISA2+sfence+po+po+WC+WB+WC | Forbid | Ok, 0/1.9G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| ISA2+sfence+po+po+WC+WC+UC | Forbid | Ok, 0/1.9G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| ISA2+sfence+po+po+WC+WC+WB | Forbid | Ok, 0/1.9G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| ISA2+sfence+po+po+WC+WC+WC | Forbid | Ok, 0/1.9G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/185M |
| W+RWC+sfence+po+mfence+WB+UC+UC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+sfence+po+mfence+WB+UC+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+sfence+po+mfence+WB+UC+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+sfence+po+mfence+WB+WB+UC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+sfence+po+mfence+WB+WB+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+sfence+po+mfence+WB+WB+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+sfence+po+mfence+WB+WC+UC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+sfence+po+mfence+WB+WC+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+sfence+po+mfence+WB+WC+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+sfence+po+mfence+WC+WB+UC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+sfence+po+mfence+WC+WB+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+sfence+po+mfence+WC+WB+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+sfence+po+mfence+WC+WC+UC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+sfence+po+mfence+WC+WC+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+sfence+po+mfence+WC+WC+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+sfence+po+mfence+WB+UC+UC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+sfence+po+mfence+WB+UC+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+sfence+po+mfence+WB+UC+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+sfence+po+mfence+WB+WB+UC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+sfence+po+mfence+WB+WB+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+sfence+po+mfence+WB+WB+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+sfence+po+mfence+WB+WC+UC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+sfence+po+mfence+WB+WC+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+sfence+po+mfence+WB+WC+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+sfence+po+mfence+WC+WB+UC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+sfence+po+mfence+WC+WB+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+sfence+po+mfence+WC+WB+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+sfence+po+mfence+WC+WC+UC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+sfence+po+mfence+WC+WC+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+sfence+po+mfence+WC+WC+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+sfence+sfence+po+UC+WB+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+sfence+sfence+po+UC+WC+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+sfence+sfence+po+UC+WC+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+sfence+sfence+po+WB+WB+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+sfence+sfence+po+WB+WC+UC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+sfence+sfence+po+WB+WC+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+sfence+sfence+po+WB+WC+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+sfence+sfence+po+WC+WB+UC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+sfence+sfence+po+WC+WB+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+sfence+sfence+po+WC+WB+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+sfence+sfence+po+WC+WC+UC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+sfence+sfence+po+WC+WC+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.1+sfence+sfence+po+WC+WC+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.2+sfence+po+po+WB+WC+UC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.2+sfence+po+po+WB+WC+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.2+sfence+po+po+WB+WC+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.2+sfence+po+po+WC+WB+UC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.2+sfence+po+po+WC+WB+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.2+sfence+po+po+WC+WB+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.2+sfence+po+po+WC+WC+UC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.2+sfence+po+po+WC+WC+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.2+sfence+po+po+WC+WC+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+sfence+sfence+po+UC+WB+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+sfence+sfence+po+UC+WC+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+sfence+sfence+po+UC+WC+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+sfence+sfence+po+WB+WB+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+sfence+sfence+po+WB+WC+UC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+sfence+sfence+po+WB+WC+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+sfence+sfence+po+WB+WC+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+sfence+sfence+po+WC+WB+UC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+sfence+sfence+po+WC+WB+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+sfence+sfence+po+WC+WB+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+sfence+sfence+po+WC+WC+UC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+sfence+sfence+po+WC+WC+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.3+sfence+sfence+po+WC+WC+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+sfence+mfence+mfence+UC+UC+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+sfence+mfence+mfence+UC+WB+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+sfence+mfence+mfence+UC+WC+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+sfence+mfence+mfence+WB+UC+UC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+sfence+mfence+mfence+WB+UC+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+sfence+mfence+mfence+WB+UC+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+sfence+mfence+mfence+WB+WB+UC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+sfence+mfence+mfence+WB+WB+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+sfence+mfence+mfence+WB+WB+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+sfence+mfence+mfence+WB+WC+UC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+sfence+mfence+mfence+WB+WC+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+sfence+mfence+mfence+WB+WC+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+sfence+mfence+mfence+WC+UC+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+sfence+mfence+mfence+WC+WB+UC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+sfence+mfence+mfence+WC+WB+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+sfence+mfence+mfence+WC+WB+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+sfence+mfence+mfence+WC+WC+UC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+sfence+mfence+mfence+WC+WC+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+sfence+mfence+mfence+WC+WC+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+sfence+sfence+mfence+UC+WB+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+sfence+sfence+mfence+UC+WC+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+sfence+sfence+mfence+UC+WC+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+sfence+sfence+mfence+WB+UC+UC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+sfence+sfence+mfence+WB+UC+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+sfence+sfence+mfence+WB+UC+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+sfence+sfence+mfence+WB+WB+UC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+sfence+sfence+mfence+WB+WB+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+sfence+sfence+mfence+WB+WB+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+sfence+sfence+mfence+WB+WC+UC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+sfence+sfence+mfence+WB+WC+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+sfence+sfence+mfence+WB+WC+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+sfence+sfence+mfence+WC+WB+UC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+sfence+sfence+mfence+WC+WB+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+sfence+sfence+mfence+WC+WB+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+sfence+sfence+mfence+WC+WC+UC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+sfence+sfence+mfence+WC+WC+WB | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+sfence+sfence+mfence+WC+WC+WC | Forbid | Ok, 0/1.8G | Ok, 0/428M | Ok, 0/44M | Ok, 0/128M | Ok, 0/550M | Ok, 0/152M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
From fence experiments, we replace mfence’s by sfence’s (hence in-between write-to-read pairs). Some of the tests are still forbidden because the mfence was in fact useless, for instance when the read of a write-to-read pair is of write-combining memory type (cf. this table).
| R+sfence+sfence+WB+UC | Allow | Ok, 4.9M/3.5G | Ok, 244k/762M | Ok, 665k/440M | Ok, 172k/240M | Ok, 2.0M/1.0G | Ok, 1.4M/227M | Ok, 176k/327M | Ok, 1/66M | Ok, 180k/173M | Ok, 1.5k/267M |
| R+sfence+sfence+WB+WB | Allow | Ok, 9.1M/3.5G | Ok, 3.3M/762M | Ok, 417k/440M | Ok, 1.3M/240M | Ok, 2.5M/1.0G | Ok, 291k/227M | Ok, 373k/327M | Ok, 11k/66M | Ok, 242k/173M | Ok, 620k/267M |
| R+sfence+sfence+WB+WC | Allow | Ok, 22M/3.5G | Ok, 5.0M/762M | Ok, 1.5M/440M | Ok, 3.7M/240M | Ok, 2.5M/1.0G | Ok, 525k/227M | Ok, 6.8M/327M | Ok, 5/66M | Ok, 1.6M/173M | Ok, 1.6k/267M |
| R+sfence+sfence+WB+WT | Allow | Ok, 2.7M/2.5G | Ok, 240k/762M | Ok, 628k/440M | Ok, 168k/240M | — | Ok, 1.3M/227M | Ok, 179k/327M | Ok, 4/66M | Ok, 180k/173M | Ok, 1.5k/267M |
| R+sfence+sfence+WC+WB | Forbid | Ok, 0/3.5G | Ok, 0/762M | Ok, 0/440M | Ok, 0/240M | Ok, 0/1.0G | Ok, 0/227M | Ok, 0/327M | Ok, 0/66M | Ok, 0/173M | Ok, 0/267M |
| R+sfence+sfence+WC+WC | Forbid | Ok, 0/3.5G | Ok, 0/762M | Ok, 0/440M | Ok, 0/240M | Ok, 0/1.0G | Ok, 0/227M | Ok, 0/327M | Ok, 0/66M | Ok, 0/173M | Ok, 0/267M |
| R+sfence+sfence+WT+UC | Allow | Ok, 16k/2.5G | Ok, 3.2k/762M | Ok, 3.8k/440M | Ok, 3.6k/240M | — | Ok, 2.1k/227M | Ok, 1.8k/327M | No, 0/66M | Ok, 1.5k/173M | No, 0/267M |
| Allow unseen | Allow unseen | ||||||||||
| R+sfence+sfence+WT+WB | Allow | Ok, 39k/2.5G | Ok, 2.3k/762M | Ok, 15k/440M | Ok, 1.0k/240M | — | Ok, 3.7k/227M | Ok, 8.9k/327M | No, 0/66M | Ok, 3.3k/173M | Ok, 4.4k/267M |
| Allow unseen | |||||||||||
| R+sfence+sfence+WT+WC | Allow | Ok, 144k/2.5G | Ok, 13k/762M | Ok, 7.3k/440M | Ok, 11k/240M | — | Ok, 33k/227M | Ok, 32k/327M | No, 0/66M | Ok, 48k/173M | No, 0/267M |
| R+sfence+sfence+WT+WT | Allow | Ok, 19k/2.5G | Ok, 3.5k/762M | Ok, 3.8k/440M | Ok, 3.3k/240M | — | Ok, 1.6k/227M | Ok, 5.2k/327M | No, 0/66M | Ok, 1.4k/173M | Ok, 2/267M |
| SB+sfences+UC+WT | Allow | Ok, 6.0k/2.5G | Ok, 113/762M | Ok, 341/440M | Ok, 546/240M | — | Ok, 987/227M | Ok, 3.1k/327M | No, 0/66M | Ok, 925/173M | No, 0/227M |
| SB+sfences+WB+UC | Allow | Ok, 2.2M/3.5G | Ok, 247k/762M | Ok, 169k/440M | Ok, 151k/240M | Ok, 1.3M/1.0G | Ok, 148k/227M | Ok, 108k/327M | Ok, 2/66M | Ok, 72k/173M | Ok, 1.4k/227M |
| SB+sfences+WB+WB | Allow | Ok, 238M/3.5G | Ok, 48M/762M | Ok, 23M/440M | Ok, 22M/240M | Ok, 123M/1.0G | Ok, 3.1M/227M | Ok, 9.4M/327M | Ok, 291k/66M | Ok, 3.9M/173M | Ok, 5.2M/227M |
| SB+sfences+WB+WC | Allow | Ok, 5.9M/3.5G | Ok, 332k/762M | Ok, 3.4M/440M | Ok, 231k/240M | Ok, 1.4M/1.0G | Ok, 401k/227M | Ok, 107k/327M | No, 0/66M | Ok, 142k/173M | Ok, 2.2k/227M |
| SB+sfences+WB+WT | Allow | Ok, 192M/2.5G | Ok, 92M/762M | Ok, 34M/440M | Ok, 46M/240M | — | Ok, 2.8M/227M | Ok, 7.1M/327M | Ok, 96k/66M | Ok, 3.1M/173M | Ok, 7.5M/227M |
| SB+sfences+WC+WT | Allow | Ok, 6.7k/2.5G | Ok, 144/762M | Ok, 1.1k/440M | Ok, 571/240M | — | Ok, 897/227M | Ok, 1.9k/327M | No, 0/66M | Ok, 2.1k/173M | No, 0/227M |
| SB+sfences+WT+WT | Allow | Ok, 289M/2.5G | Ok, 157M/762M | Ok, 33M/440M | Ok, 81M/240M | — | Ok, 1.5M/227M | Ok, 7.7M/327M | Ok, 219k/66M | Ok, 3.0M/173M | Ok, 5.8M/227M |
| RWC+po+sfence+WB+UC | Allow | Ok, 2.0M/3.6G | Ok, 137k/896M | Ok, 1.3M/828M | Ok, 3.5k/672M | Ok, 381k/524M | Ok, 105k/142M | Ok, 14k/218M | No, 0/33M | Ok, 88k/115M | No, 0/185M |
| RWC+po+sfence+WB+WB | Allow | Ok, 2.6M/3.6G | Ok, 432k/896M | Ok, 676k/828M | Ok, 1.1M/672M | Ok, 257k/524M | Ok, 19k/142M | Ok, 50k/218M | Ok, 1.4k/33M | Ok, 43k/115M | Ok, 37k/185M |
| RWC+po+sfence+WB+WC | Allow | Ok, 2.0M/3.6G | Ok, 149k/896M | Ok, 1.2M/828M | Ok, 3.9k/672M | Ok, 411k/524M | Ok, 121k/142M | Ok, 12k/218M | No, 0/33M | Ok, 56k/115M | No, 0/185M |
| WRW+WR+po+sfence+WB+UC | Allow | Ok, 885k/3.6G | Ok, 132k/896M | Ok, 291k/828M | Ok, 7.7k/672M | Ok, 106k/524M | Ok, 77k/142M | Ok, 36k/218M | Ok, 1/33M | Ok, 235k/115M | No, 0/161M |
| WRW+WR+po+sfence+WB+WB | Allow | Ok, 753k/3.6G | Ok, 172k/896M | Ok, 65k/828M | Ok, 430k/672M | Ok, 30k/524M | Ok, 7.5k/142M | Ok, 13k/218M | Ok, 372/33M | Ok, 14k/115M | Ok, 21k/161M |
| WRW+WR+po+sfence+WB+WC | Allow | Ok, 3.2M/3.6G | Ok, 361k/896M | Ok, 192k/828M | Ok, 31k/672M | Ok, 1.1M/524M | Ok, 733k/142M | Ok, 175k/218M | No, 0/33M | Ok, 544k/115M | No, 0/161M |
| 3.SB+sfences+WB+UC+UC | Allow | Ok, 243/2.0G | No, 0/388M | No, 0/220M | No, 0/128M | Ok, 3/518M | Ok, 4/151M | Ok, 187/218M | No, 0/33M | Ok, 49/115M | No, 0/185M |
| Allow unseen | Allow unseen | Allow unseen | Allow unseen | Allow unseen | |||||||
| 3.SB+sfences+WB+WB+UC | Allow | Ok, 4.1M/2.0G | Ok, 336k/388M | Ok, 483k/220M | Ok, 258k/128M | Ok, 2.5M/518M | Ok, 82k/151M | Ok, 189k/218M | Ok, 141/33M | Ok, 202k/115M | Ok, 23k/185M |
| 3.SB+sfences+WB+WB+WB | Allow | Ok, 61M/2.0G | Ok, 14M/388M | Ok, 5.6M/220M | Ok, 8.4M/128M | Ok, 29M/518M | Ok, 455k/151M | Ok, 1.4M/218M | Ok, 13k/33M | Ok, 484k/115M | Ok, 842k/185M |
| 3.SB+sfences+WB+WB+WC | Allow | Ok, 4.5M/2.0G | Ok, 429k/388M | Ok, 504k/220M | Ok, 284k/128M | Ok, 2.8M/518M | Ok, 81k/151M | Ok, 177k/218M | Ok, 186/33M | Ok, 158k/115M | Ok, 27k/185M |
| 3.SB+sfences+WB+WC+UC | Allow | Ok, 574/2.0G | No, 0/388M | Ok, 1/220M | Ok, 1/128M | Ok, 5/518M | Ok, 11/151M | Ok, 269/218M | No, 0/33M | Ok, 287/115M | No, 0/185M |
| Allow unseen | Allow unseen | Allow unseen | |||||||||
| 3.SB+sfences+WB+WC+WC | Allow | Ok, 941/2.0G | No, 0/388M | No, 0/220M | No, 0/128M | Ok, 2/518M | Ok, 4/151M | Ok, 468/218M | No, 0/33M | Ok, 467/115M | No, 0/185M |
| W+RWC+sfence+po+sfence+WB+UC+UC | Allow | Ok, 380/1.9G | No, 0/388M | Ok, 2/220M | No, 0/128M | Ok, 8/518M | Ok, 44/151M | Ok, 232/218M | No, 0/33M | Ok, 94/115M | No, 0/161M |
| Allow unseen | Allow unseen | Allow unseen | Allow unseen | ||||||||
| W+RWC+sfence+po+sfence+WB+UC+WB | Allow | Ok, 2.6k/1.9G | No, 0/388M | Ok, 9/220M | Ok, 2/128M | Ok, 17/518M | Ok, 29/151M | Ok, 763/218M | No, 0/33M | Ok, 860/115M | Ok, 883/161M |
| W+RWC+sfence+po+sfence+WB+UC+WC | Allow | Ok, 1.2k/1.9G | No, 0/388M | Ok, 1/220M | No, 0/128M | Ok, 2/518M | Ok, 53/151M | Ok, 500/218M | No, 0/33M | Ok, 652/115M | No, 0/161M |
| W+RWC+sfence+po+sfence+WB+WB+UC | Allow | Ok, 482k/1.9G | Ok, 32k/388M | Ok, 149k/220M | Ok, 17k/128M | Ok, 140k/518M | Ok, 77k/151M | Ok, 7.9k/218M | No, 0/33M | Ok, 58k/115M | No, 0/161M |
| W+RWC+sfence+po+sfence+WB+WB+WB | Allow | Ok, 48k/1.9G | Ok, 4.8k/388M | Ok, 1.2k/220M | Ok, 2.6k/128M | Ok, 10k/518M | Ok, 1.3k/151M | Ok, 7.3k/218M | Ok, 15/33M | Ok, 9.3k/115M | Ok, 12k/161M |
| W+RWC+sfence+po+sfence+WB+WB+WC | Allow | Ok, 486k/1.9G | Ok, 34k/388M | Ok, 134k/220M | Ok, 14k/128M | Ok, 153k/518M | Ok, 63k/151M | Ok, 6.8k/218M | No, 0/33M | Ok, 80k/115M | No, 0/161M |
| W+RWC+sfence+po+sfence+WB+WC+UC | Allow | Ok, 3.5k/1.9G | No, 0/388M | No, 0/220M | No, 0/128M | Ok, 77/518M | Ok, 782/151M | Ok, 1.3k/218M | No, 0/33M | Ok, 1.3k/115M | No, 0/161M |
| W+RWC+sfence+po+sfence+WB+WC+WB | Allow | Ok, 1.2k/1.9G | Ok, 33/388M | Ok, 4/220M | Ok, 18/128M | Ok, 12/518M | Ok, 15/151M | Ok, 200/218M | No, 0/33M | Ok, 565/115M | Ok, 323/161M |
| W+RWC+sfence+po+sfence+WB+WC+WC | Allow | Ok, 2.2k/1.9G | No, 0/388M | No, 0/220M | No, 0/128M | Ok, 19/518M | Ok, 744/151M | Ok, 825/218M | No, 0/33M | Ok, 608/115M | No, 0/161M |
| W+RWC+sfence+po+sfence+WC+WB+UC | Forbid | Ok, 0/1.9G | Ok, 0/388M | Ok, 0/220M | Ok, 0/128M | Ok, 0/518M | Ok, 0/151M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+sfence+po+sfence+WC+WB+WB | Forbid | Ok, 0/1.9G | Ok, 0/388M | Ok, 0/220M | Ok, 0/128M | Ok, 0/518M | Ok, 0/151M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+sfence+po+sfence+WC+WB+WC | Forbid | Ok, 0/1.9G | Ok, 0/388M | Ok, 0/220M | Ok, 0/128M | Ok, 0/518M | Ok, 0/151M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+sfence+po+sfence+WC+WC+UC | Forbid | Ok, 0/1.9G | Ok, 0/388M | Ok, 0/220M | Ok, 0/128M | Ok, 0/518M | Ok, 0/151M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+sfence+po+sfence+WC+WC+WB | Forbid | Ok, 0/1.9G | Ok, 0/388M | Ok, 0/220M | Ok, 0/128M | Ok, 0/518M | Ok, 0/151M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| W+RWC+sfence+po+sfence+WC+WC+WC | Forbid | Ok, 0/1.9G | Ok, 0/388M | Ok, 0/220M | Ok, 0/128M | Ok, 0/518M | Ok, 0/151M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+sfence+po+sfence+WB+UC+UC | Allow | Ok, 1.1k/1.9G | No, 0/388M | Ok, 4/220M | No, 0/128M | Ok, 15/518M | Ok, 70/151M | Ok, 680/218M | No, 0/33M | Ok, 283/115M | No, 0/161M |
| Z6.0+sfence+po+sfence+WB+UC+WB | Allow | Ok, 1.5k/1.9G | Ok, 4/388M | Ok, 2/220M | Ok, 2/128M | Ok, 6/518M | Ok, 17/151M | Ok, 247/218M | No, 0/33M | Ok, 774/115M | Ok, 449/161M |
| Z6.0+sfence+po+sfence+WB+UC+WC | Allow | Ok, 3.5k/1.9G | Ok, 1/388M | Ok, 3/220M | Ok, 7/128M | Ok, 36/518M | Ok, 678/151M | Ok, 1.5k/218M | No, 0/33M | Ok, 1.3k/115M | No, 0/161M |
| Z6.0+sfence+po+sfence+WB+WB+UC | Allow | Ok, 311k/1.9G | Ok, 3.7k/388M | Ok, 3.9k/220M | Ok, 5.5k/128M | Ok, 46k/518M | Ok, 71k/151M | Ok, 4.9k/218M | No, 0/33M | Ok, 176k/115M | No, 0/161M |
| Z6.0+sfence+po+sfence+WB+WB+WB | Allow | Ok, 25k/1.9G | Ok, 2.8k/388M | Ok, 243/220M | Ok, 1.8k/128M | Ok, 2.3k/518M | Ok, 1.6k/151M | Ok, 3.9k/218M | Ok, 2/33M | Ok, 5.2k/115M | Ok, 7.3k/161M |
| Z6.0+sfence+po+sfence+WB+WB+WC | Allow | Ok, 2.1M/1.9G | Ok, 30k/388M | Ok, 13k/220M | Ok, 36k/128M | Ok, 791k/518M | Ok, 755k/151M | Ok, 106k/218M | No, 0/33M | Ok, 401k/115M | No, 0/161M |
| Z6.0+sfence+po+sfence+WB+WC+UC | Allow | Ok, 10k/1.9G | Ok, 16/388M | Ok, 6/220M | No, 0/128M | Ok, 2.2k/518M | Ok, 1.3k/151M | Ok, 3.7k/218M | No, 0/33M | Ok, 3.1k/115M | No, 0/161M |
| Z6.0+sfence+po+sfence+WB+WC+WB | Allow | Ok, 1.2k/1.9G | Ok, 76/388M | No, 0/220M | Ok, 49/128M | Ok, 10/518M | Ok, 8/151M | Ok, 243/218M | No, 0/33M | Ok, 416/115M | Ok, 348/161M |
| Z6.0+sfence+po+sfence+WB+WC+WC | Allow | Ok, 1.1k/1.9G | No, 0/388M | No, 0/220M | Ok, 1/128M | Ok, 21/518M | Ok, 195/151M | Ok, 542/218M | No, 0/33M | Ok, 335/115M | No, 0/161M |
| Z6.0+sfence+po+sfence+WC+WB+UC | Forbid | Ok, 0/1.9G | Ok, 0/388M | Ok, 0/220M | Ok, 0/128M | Ok, 0/518M | Ok, 0/151M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+sfence+po+sfence+WC+WB+WB | Forbid | Ok, 0/1.9G | Ok, 0/388M | Ok, 0/220M | Ok, 0/128M | Ok, 0/518M | Ok, 0/151M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+sfence+po+sfence+WC+WB+WC | Forbid | Ok, 0/1.9G | Ok, 0/388M | Ok, 0/220M | Ok, 0/128M | Ok, 0/518M | Ok, 0/151M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+sfence+po+sfence+WC+WC+UC | Forbid | Ok, 0/1.9G | Ok, 0/388M | Ok, 0/220M | Ok, 0/128M | Ok, 0/518M | Ok, 0/151M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+sfence+po+sfence+WC+WC+WB | Forbid | Ok, 0/1.9G | Ok, 0/388M | Ok, 0/220M | Ok, 0/128M | Ok, 0/518M | Ok, 0/151M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.0+sfence+po+sfence+WC+WC+WC | Forbid | Ok, 0/1.9G | Ok, 0/388M | Ok, 0/220M | Ok, 0/128M | Ok, 0/518M | Ok, 0/151M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+sfence+sfence+sfence+UC+UC+WB | Allow | Ok, 307/1.9G | Ok, 15/388M | Ok, 2/220M | Ok, 4/128M | Ok, 1/518M | Ok, 12/151M | Ok, 146/218M | No, 0/33M | Ok, 127/115M | No, 0/161M |
| Z6.4+sfence+sfence+sfence+UC+WB+WB | Allow | Ok, 1.7k/1.9G | No, 0/388M | Ok, 1/220M | No, 0/128M | Ok, 4/518M | Ok, 11/151M | Ok, 961/218M | No, 0/33M | Ok, 620/115M | Ok, 58/161M |
| Z6.4+sfence+sfence+sfence+UC+WC+WB | Allow | Ok, 2.9k/1.9G | Ok, 1/388M | Ok, 2/220M | Ok, 3/128M | Ok, 19/518M | Ok, 447/151M | Ok, 1.2k/218M | No, 0/33M | Ok, 1.2k/115M | No, 0/161M |
| Z6.4+sfence+sfence+sfence+WB+UC+UC | Allow | Ok, 117/1.9G | No, 0/388M | No, 0/220M | Ok, 1/128M | Ok, 2/518M | Ok, 14/151M | Ok, 62/218M | No, 0/33M | Ok, 38/115M | No, 0/161M |
| Z6.4+sfence+sfence+sfence+WB+UC+WB | Allow | Ok, 3.1M/1.9G | Ok, 101k/388M | Ok, 622k/220M | Ok, 118k/128M | Ok, 1.3M/518M | Ok, 468k/151M | Ok, 36k/218M | Ok, 25/33M | Ok, 56k/115M | Ok, 448k/161M |
| Z6.4+sfence+sfence+sfence+WB+UC+WC | Allow | Ok, 303/1.9G | No, 0/388M | Ok, 3/220M | Ok, 2/128M | Ok, 3/518M | Ok, 14/151M | Ok, 59/218M | No, 0/33M | Ok, 222/115M | No, 0/161M |
| Z6.4+sfence+sfence+sfence+WB+WB+UC | Allow | Ok, 412k/1.9G | Ok, 35k/388M | Ok, 86k/220M | Ok, 15k/128M | Ok, 111k/518M | Ok, 57k/151M | Ok, 9.4k/218M | No, 0/33M | Ok, 98k/115M | No, 0/161M |
| Z6.4+sfence+sfence+sfence+WB+WB+WB | Allow | Ok, 5.0M/1.9G | Ok, 962k/388M | Ok, 1.5M/220M | Ok, 556k/128M | Ok, 1.6M/518M | Ok, 25k/151M | Ok, 52k/218M | Ok, 407/33M | Ok, 56k/115M | Ok, 269k/161M |
| Z6.4+sfence+sfence+sfence+WB+WB+WC | Allow | Ok, 407k/1.9G | Ok, 41k/388M | Ok, 75k/220M | Ok, 19k/128M | Ok, 120k/518M | Ok, 62k/151M | Ok, 5.5k/218M | No, 0/33M | Ok, 83k/115M | No, 0/161M |
| Z6.4+sfence+sfence+sfence+WB+WC+UC | Allow | Ok, 669/1.9G | Ok, 4/388M | Ok, 11/220M | Ok, 1/128M | Ok, 89/518M | Ok, 48/151M | Ok, 197/218M | No, 0/33M | Ok, 319/115M | No, 0/161M |
| Z6.4+sfence+sfence+sfence+WB+WC+WB | Allow | Ok, 2.3M/1.9G | Ok, 187k/388M | Ok, 85k/220M | Ok, 205k/128M | Ok, 617k/518M | Ok, 67k/151M | Ok, 574k/218M | Ok, 51/33M | Ok, 368k/115M | Ok, 212k/161M |
| Z6.4+sfence+sfence+sfence+WB+WC+WC | Allow | Ok, 539/1.9G | Ok, 10/388M | Ok, 3/220M | Ok, 1/128M | Ok, 5/518M | Ok, 61/151M | Ok, 89/218M | No, 0/33M | Ok, 370/115M | No, 0/161M |
| Z6.4+sfence+sfence+sfence+WC+UC+WB | Allow | Ok, 380/1.9G | No, 0/388M | Ok, 2/220M | Ok, 4/128M | Ok, 1/518M | Ok, 13/151M | Ok, 107/218M | No, 0/33M | Ok, 253/115M | No, 0/161M |
| Z6.4+sfence+sfence+sfence+WC+WB+UC | Forbid | Ok, 0/1.9G | Ok, 0/388M | Ok, 0/220M | Ok, 0/128M | Ok, 0/518M | Ok, 0/151M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+sfence+sfence+sfence+WC+WB+WB | Allow | Ok, 2.1k/1.9G | Ok, 22/388M | No, 0/220M | Ok, 12/128M | Ok, 5/518M | Ok, 11/151M | Ok, 1.2k/218M | No, 0/33M | Ok, 755/115M | Ok, 75/161M |
| Z6.4+sfence+sfence+sfence+WC+WB+WC | Forbid | Ok, 0/1.9G | Ok, 0/388M | Ok, 0/220M | Ok, 0/128M | Ok, 0/518M | Ok, 0/151M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+sfence+sfence+sfence+WC+WC+UC | Forbid | Ok, 0/1.9G | Ok, 0/388M | Ok, 0/220M | Ok, 0/128M | Ok, 0/518M | Ok, 0/151M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.4+sfence+sfence+sfence+WC+WC+WB | Allow | Ok, 3.6k/1.9G | Ok, 4/388M | Ok, 1/220M | Ok, 8/128M | Ok, 143/518M | Ok, 695/151M | Ok, 1.4k/218M | No, 0/33M | Ok, 1.3k/115M | No, 0/161M |
| Z6.4+sfence+sfence+sfence+WC+WC+WC | Forbid | Ok, 0/1.9G | Ok, 0/388M | Ok, 0/220M | Ok, 0/128M | Ok, 0/518M | Ok, 0/151M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+sfence+sfence+sfence+UC+WB+WC | Forbid | Ok, 0/1.9G | Ok, 0/388M | Ok, 0/220M | Ok, 0/128M | Ok, 0/518M | Ok, 0/151M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+sfence+sfence+sfence+UC+WC+WB | Forbid | Ok, 0/1.9G | Ok, 0/388M | Ok, 0/220M | Ok, 0/128M | Ok, 0/518M | Ok, 0/151M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+sfence+sfence+sfence+UC+WC+WC | Forbid | Ok, 0/1.9G | Ok, 0/388M | Ok, 0/220M | Ok, 0/128M | Ok, 0/518M | Ok, 0/151M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+sfence+sfence+sfence+WB+UC+UC | Allow | Ok, 312/1.9G | Ok, 1/388M | Ok, 8/220M | Ok, 2/128M | Ok, 3/518M | Ok, 20/151M | Ok, 188/218M | No, 0/33M | Ok, 90/115M | No, 0/161M |
| Z6.5+sfence+sfence+sfence+WB+UC+WB | Allow | Ok, 265/1.9G | Ok, 1/388M | Ok, 20/220M | Ok, 11/128M | Ok, 6/518M | Ok, 5/151M | Ok, 147/218M | No, 0/33M | Ok, 75/115M | No, 0/161M |
| Z6.5+sfence+sfence+sfence+WB+UC+WC | Allow | Ok, 1.6k/1.9G | Ok, 16/388M | Ok, 69/220M | Ok, 16/128M | Ok, 26/518M | Ok, 487/151M | Ok, 280/218M | No, 0/33M | Ok, 679/115M | No, 0/161M |
| Z6.5+sfence+sfence+sfence+WB+WB+UC | Allow | Ok, 564k/1.9G | Ok, 8.6k/388M | Ok, 56k/220M | Ok, 8.2k/128M | Ok, 108k/518M | Ok, 180k/151M | Ok, 12k/218M | No, 0/33M | Ok, 192k/115M | No, 0/161M |
| Z6.5+sfence+sfence+sfence+WB+WB+WB | Allow | Ok, 22k/1.9G | Ok, 3.2k/388M | Ok, 666/220M | Ok, 2.2k/128M | Ok, 2.3k/518M | Ok, 649/151M | Ok, 3.4k/218M | Ok, 1/33M | Ok, 5.3k/115M | Ok, 4.3k/161M |
| Z6.5+sfence+sfence+sfence+WB+WB+WC | Allow | Ok, 551k/1.9G | Ok, 27k/388M | Ok, 34k/220M | Ok, 20k/128M | Ok, 131k/518M | Ok, 39k/151M | Ok, 162k/218M | No, 0/33M | Ok, 139k/115M | No, 0/161M |
| Z6.5+sfence+sfence+sfence+WB+WC+UC | Allow | Ok, 3.7k/1.9G | Ok, 532/388M | Ok, 216/220M | Ok, 271/128M | Ok, 257/518M | Ok, 79/151M | Ok, 836/218M | No, 0/33M | Ok, 1.5k/115M | No, 0/161M |
| Z6.5+sfence+sfence+sfence+WB+WC+WB | Allow | Ok, 1.5k/1.9G | Ok, 310/388M | Ok, 308/220M | Ok, 250/128M | Ok, 46/518M | Ok, 5/151M | Ok, 120/218M | No, 0/33M | Ok, 485/115M | Ok, 1/161M |
| Z6.5+sfence+sfence+sfence+WB+WC+WC | Allow | Ok, 99k/1.9G | Ok, 15k/388M | Ok, 40k/220M | Ok, 22k/128M | Ok, 2.8k/518M | Ok, 3.8k/151M | Ok, 11k/218M | No, 0/33M | Ok, 4.9k/115M | No, 0/161M |
| Z6.5+sfence+sfence+sfence+WC+WB+UC | Forbid | Ok, 0/1.9G | Ok, 0/388M | Ok, 0/220M | Ok, 0/128M | Ok, 0/518M | Ok, 0/151M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+sfence+sfence+sfence+WC+WB+WB | Forbid | Ok, 0/1.9G | Ok, 0/388M | Ok, 0/220M | Ok, 0/128M | Ok, 0/518M | Ok, 0/151M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+sfence+sfence+sfence+WC+WB+WC | Forbid | Ok, 0/1.9G | Ok, 0/388M | Ok, 0/220M | Ok, 0/128M | Ok, 0/518M | Ok, 0/151M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+sfence+sfence+sfence+WC+WC+UC | Forbid | Ok, 0/1.9G | Ok, 0/388M | Ok, 0/220M | Ok, 0/128M | Ok, 0/518M | Ok, 0/151M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+sfence+sfence+sfence+WC+WC+WB | Forbid | Ok, 0/1.9G | Ok, 0/388M | Ok, 0/220M | Ok, 0/128M | Ok, 0/518M | Ok, 0/151M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
| Z6.5+sfence+sfence+sfence+WC+WC+WC | Forbid | Ok, 0/1.9G | Ok, 0/388M | Ok, 0/220M | Ok, 0/128M | Ok, 0/518M | Ok, 0/151M | Ok, 0/218M | Ok, 0/33M | Ok, 0/115M | Ok, 0/161M |
