| | Flowing | ARM-Model | Model | Op | Hardware |
| LB+data+pos-fri-rfi-addr | Forbid | Allow | Forbid | Forbid | Ok, 103k/29G |
| LB+data+pos-fri-rfi-ctrl | Forbid | Allow | Forbid | Forbid | Ok, 115k/29G |
| LB+data+pos-fri-rfi-data | Forbid | Allow | Forbid | Forbid | Ok, 113k/29G |
| MP+dmb+pos-fri-rfi-ctrlisb | Forbid | Allow | Forbid | Forbid | Ok, 65k/97G |
| S+dmb+pos-fri-rfi-addr | Forbid | Allow | Forbid | Forbid | Ok, 367k/27G |
| S+dmb+pos-fri-rfi-ctrl | Forbid | Allow | Forbid | Forbid | Ok, 357k/26G |
| S+dmb+pos-fri-rfi-data | Forbid | Allow | Forbid | Forbid | Ok, 365k/26G |
| LB+data+pos-fri-rfi-addr-po | Forbid | Allow | Forbid | Forbid | Ok, 230k/26G |
| LB+data+pos-fri-rfi-addr-po001 | Forbid | Allow | Forbid | Forbid | Ok, 146k/26G |
| LB+data+pos-fri-rfi-ctrl-po | Forbid | Allow | Forbid | Forbid | Ok, 156k/23G |
| MP+dmb+pos-fri-rfi-data-rfi | Forbid | Allow | Forbid | Forbid | Ok, 167k/23G |
| S+dmb+pos-fri-rfi-addr-addr | Forbid | Allow | Forbid | Forbid | Ok, 19k/25G |
| S+dmb+pos-fri-rfi-addr-ctrl | Forbid | Allow | Forbid | Forbid | Ok, 32k/23G |
| S+dmb+pos-fri-rfi-addr-data | Forbid | Allow | Forbid | Forbid | Ok, 36k/25G |
| S+dmb+pos-fri-rfi-addr-fri | Forbid | Allow | Forbid | Forbid | Ok, 590k/25G |
| S+dmb+pos-fri-rfi-pos-ctrl | Forbid | Allow | Forbid | Forbid | Ok, 161k/23G |
| LB+data+pos-fri-rfi-addr-addr-po | Forbid | Allow | Forbid | Forbid | Ok, 18k/26G |
| LB+data+pos-fri-rfi-addr-ctrl-po | Forbid | Allow | Forbid | Forbid | Ok, 24k/23G |
| LB+data+pos-fri-rfi-addr-data-po | Forbid | Allow | Forbid | Forbid | Ok, 39k/23G |
| LB+data+pos-fri-rfi-addr-fri-po | Forbid | Allow | Forbid | Forbid | Ok, 133k/26G |
| LB+data+pos-fri-rfi-addr-rfi-po | Forbid | Allow | Forbid | Forbid | Ok, 124k/23G |
| LB+data+pos-fri-rfi-addr-wsi-po | Forbid | Allow | Forbid | Forbid | Ok, 121k/25G |
| LB+data+pos-fri-rfi-ctrl-wsi-po | Forbid | Allow | Forbid | Forbid | Ok, 116k/23G |
| LB+data+pos-fri-rfi-pos-ctrl-po | Forbid | Allow | Forbid | Forbid | Ok, 116k/26G |
| S+dmb+pos-fri-rfi-data-rfi-ctrl | Forbid | Allow | Forbid | Forbid | Ok, 29k/25G |
| MOREDETOUR0240 | Forbid | Allow | Forbid | Forbid | No, 0/18G |
| | | | | | Allow unseen |
| LB+data+data-detww+LOCAL | Forbid | Allow | Forbid | — | No, 0/1.8G |
| | | | | | Allow unseen |
| LB+data+detr-fri-rfi-addr | Forbid | Allow | Forbid | Forbid | Ok, 199k/6.5G |
| LB+data+detr-fri-rfi-ctrl | Forbid | Allow | Forbid | Forbid | Ok, 177k/6.5G |
| LB+data+detr-fri-rfi-data | Forbid | Allow | Forbid | Forbid | Ok, 184k/6.5G |
| MOREDETOUR0253 | Forbid | Allow | Forbid | Forbid | No, 0/16G |
| | | | | | Allow unseen |
| MOREDETOUR0354 | Forbid | Allow | Forbid | Forbid | No, 0/16G |
| | | | | | Allow unseen |
| MOREDETOUR0151 | Forbid | Allow | Forbid | — | No, 0/11G |
| | | | | | Allow unseen |
