ARM DETOUR1174 "DMBdWW Rfe DpAddrdR Fri Rfi PosRW Wse" Cycle=Rfi PosRW Wse DMBdWW Rfe DpAddrdR Fri Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Ws Orig=DMBdWW Rfe DpAddrdR Fri Rfi PosRW Wse { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; MOV R0,#3 | LDR R0,[%y1] ; STR R0,[%x0] | EOR R1,R0,R0 ; DMB | LDR R2,[R1,%x1] ; MOV R1,#1 | MOV R3,#1 ; STR R1,[%y0] | STR R3,[%x1] ; | LDR R4,[%x1] ; | MOV R5,#2 ; | STR R5,[%x1] ; Observed 1:R0=0; 1:R2=0; 1:R4=2; x=2; and 1:R0=0; 1:R2=3; 1:R4=2; x=2; and 1:R0=1; 1:R2=3; 1:R4=2; x=2; and 1:R0=0; 1:R2=0; 1:R4=2; x=3; and 1:R0=0; 1:R2=0; 1:R4=3; x=3;
