ARM MOREDETOUR0154 "DpDatadW Rfe DpCtrldR Fri Rfi PosRW Rfe" Cycle=Rfi PosRW Rfe DpDatadW Rfe DpCtrldR Fri Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Rf Orig=DpDatadW Rfe DpCtrldR Fri Rfi PosRW Rfe { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; LDR R0,[%x0] | LDR R0,[%y1] ; EOR R1,R0,R0 | CMP R0,R0 ; ADD R1,R1,#1 | BNE LC00 ; STR R1,[%y0] | LC00: ; | LDR R1,[%x1] ; | MOV R2,#1 ; | STR R2,[%x1] ; | LDR R3,[%x1] ; | MOV R4,#2 ; | STR R4,[%x1] ; Observed 0:R0=0; 1:R0=0; 1:R1=0; 1:R3=2; and 0:R0=2; 1:R0=0; 1:R1=0; 1:R3=2; and 0:R0=0; 1:R0=1; 1:R1=0; 1:R3=2;
