Test coRR+W-DSB-TLBI-DSB-HU+rfe-W
AArch64 coRR+W-DSB-TLBI-DSB-HU+rfe-W
TTHM=HD
pte_z=(dbm:1,db:0);
y=1;
0:X1=x;
1:X3=pte_x;
1:X0=(oa:phy_x,valid:0);
1:X1=x;
1:X5=1;
1:X6=z;
2:X6=pte_z;
2:X3=pte_x;
2:X4=(oa:phy_y);
P0             | P1              | P2          ;
L1:LDR W2,[X1] | STR X0,[X3]     | LDR X0,[X6] ;
L0:LDR W4,[X1] | DSB ISH         | DMB ISH     ;
               | LSR X9,X1,#12   | STR X4,[X3] ;
               | TLBI VAAE1IS,X9 |             ;
               | DSB ISH         |             ;
               | STR W5,[X6]     |             ;
exists (0:X2=1 /\ 0:X4=0 /\ 2:X0=(oa:PA(z), dbm:1) /\ ~fault(P0:L0,x)) \/ (0:X2=1 /\ 0:X4=0 /\ 2:X0=(oa:PA(z), dbm:1) /\ fault(P0:L0,x,MMU:Translation))
