AArch64 WRC+posWppteva-tlbi-sync.ishsptevapteoa.va+pos
"Rfe PosRWPPteVA TLBI-sync.ISHsWWPteVAPteOA.VA RfePteOA.VAP PosRR Fre"
Variant=imprecise
Cycle=Rfe PosRWPPteVA TLBI-sync.ISHsWWPteVAPteOA.VA RfePteOA.VAP PosRR Fre
Relax=[PteVA,TLBI-sync.ISHsWW,PteOA,PteVA]
Safe=Rfe Fre PosRW PosRR
Generator=diy7 (version 7.56+02~dev)
Com=Rf Rf Fr
Orig=Rfe PosRWPPteVA TLBI-sync.ISHsWWPteVAPteOA.VA RfePteOA.VAP PosRR Fre
{ int x=0; int y=4;
0:X1=x;
1:X0=x; 1:X2=PTE(x); 1:X3=(oa:PA(x), valid:0); 1:X4=(oa:PA(y));
2:X0=x;
P0 | P1 | P2 ;
MOV W0,#1 | LDR W1,[X0] | LDR W1,[X0] ;
STR W0,[X1] | STR X3,[X2] | LDR W2,[X0] ;
| LSR X5,X0,#12 | ;
| DSB ISH | ;
| TLBI VAAE1IS,X5 | ;
| DSB ISH | ;
| STR X4,[X2] | ;
exists (1:X1=0 /\ 2:X1=0 /\ 2:X2=0 /\ fault(P0,x,MMU:Translation) /\ fault(P2,x,MMU:Translation) /\ ~fault(P1,x)) \/ (1:X1=0 /\ 2:X1=0 /\ 2:X2=0 /\ fault(P2,x,MMU:Translation) /\ ~fault(P0,x) /\ ~fault(P1,x)) \/ (1:X1=0 /\ 2:X1=1 /\ 2:X2=4 /\ fault(P0,x,MMU:Translation) /\ ~fault(P1,x) /\ ~fault(P2,x)) \/ (1:X1=0 /\ 2:X1=1 /\ 2:X2=4 /\ fault(P0,x,MMU:Translation) /\ fault(P2,x,MMU:Translation) /\ ~fault(P1,x)) \/ (1:X1=0 /\ 2:X1=4 /\ 2:X2=1 /\ fault(P2,x,MMU:Translation) /\ ~fault(P0,x) /\ ~fault(P1,x)) \/ (1:X1=1 /\ 2:X1=0 /\ 2:X2=0 /\ fault(P0,x,MMU:Translation) /\ ~fault(P1,x) /\ ~fault(P2,x)) \/ (1:X1=1 /\ 2:X1=0 /\ 2:X2=0 /\ fault(P0,x,MMU:Translation) /\ fault(P2,x,MMU:Translation) /\ ~fault(P1,x)) \/ (1:X1=1 /\ 2:X1=0 /\ 2:X2=0 /\ fault(P2,x,MMU:Translation) /\ ~fault(P0,x) /\ ~fault(P1,x)) \/ (1:X1=1 /\ 2:X1=0 /\ 2:X2=1 /\ fault(P0,x,MMU:Translation) /\ ~fault(P1,x) /\ ~fault(P2,x)) \/ (1:X1=1 /\ 2:X1=0 /\ 2:X2=1 /\ fault(P0,x,MMU:Translation) /\ fault(P2,x,MMU:Translation) /\ ~fault(P1,x)) \/ (1:X1=1 /\ 2:X1=0 /\ 2:X2=1 /\ fault(P2,x,MMU:Translation) /\ ~fault(P0,x) /\ ~fault(P1,x)) \/ (1:X1=1 /\ 2:X1=0 /\ 2:X2=4 /\ fault(P0,x,MMU:Translation) /\ ~fault(P1,x) /\ ~fault(P2,x)) \/ (1:X1=1 /\ 2:X1=0 /\ 2:X2=4 /\ fault(P0,x,MMU:Translation) /\ fault(P2,x,MMU:Translation) /\ ~fault(P1,x)) \/ (1:X1=1 /\ 2:X1=1 /\ 2:X2=1 /\ fault(P0,x,MMU:Translation) /\ ~fault(P1,x) /\ ~fault(P2,x)) \/ (1:X1=1 /\ 2:X1=1 /\ 2:X2=1 /\ fault(P0,x,MMU:Translation) /\ fault(P2,x,MMU:Translation) /\ ~fault(P1,x)) \/ (1:X1=1 /\ 2:X1=1 /\ 2:X2=1 /\ fault(P2,x,MMU:Translation) /\ ~fault(P0,x) /\ ~fault(P1,x)) \/ (1:X1=1 /\ 2:X1=1 /\ 2:X2=4 /\ fault(P0,x,MMU:Translation) /\ ~fault(P1,x) /\ ~fault(P2,x)) \/ (1:X1=1 /\ 2:X1=1 /\ 2:X2=4 /\ fault(P0,x,MMU:Translation) /\ fault(P2,x,MMU:Translation) /\ ~fault(P1,x)) \/ (1:X1=1 /\ 2:X1=4 /\ 2:X2=4 /\ fault(P0,x,MMU:Translation) /\ ~fault(P1,x) /\ ~fault(P2,x)) \/ (1:X1=1 /\ 2:X1=4 /\ 2:X2=4 /\ fault(P0,x,MMU:Translation) /\ fault(P2,x,MMU:Translation) /\ ~fault(P1,x))
