Test SB+pos+posWppteva-tlbi-sync.ishsWptevapteoa.va-pospteoa.vap
AArch64 SB+pos+posWppteva-tlbi-sync.ishsWptevapteoa.va-pospteoa.vap
"PosWR Fre PosWWPPteVA TLBI-sync.ISHsWWPteVAPteOA.VA PosWRPteOA.VAP Fre"
Variant=imprecise
Cycle=Fre PosWR Fre PosWWPPteVA TLBI-sync.ISHsWWPteVAPteOA.VA PosWRPteOA.VAP
Relax=[PteVA,TLBI-sync.ISHsWW,PteOA,PteVA]
Safe=Fre PosWW PosWR
Generator=diy7 (version 7.56+02~dev)
Com=Fr Fr
Orig=PosWR Fre PosWWPPteVA TLBI-sync.ISHsWWPteVAPteOA.VA PosWRPteOA.VAP Fre
{ int x=0; int y=4;
0:X1=x;
1:X1=x; 1:X2=PTE(x); 1:X3=(oa:PA(x), valid:0); 1:X4=(oa:PA(y));
 P0          | P1              ;
 MOV W0,#1   | MOV W0,#2       ;
 STR W0,[X1] | STR W0,[X1]     ;
 LDR W2,[X1] | STR X3,[X2]     ;
             | LSR X6,X1,#12   ;
             | DSB ISH         ;
             | TLBI VAAE1IS,X6 ;
             | DSB ISH         ;
             | STR X4,[X2]     ;
             | LDR W5,[X1]     ;
exists (0:X2=1 /\ 1:X5=1 /\ [x]=1 /\ ~fault(P0,x) /\ ~fault(P1,x)) \/ (0:X2=1 /\ 1:X5=1 /\ [x]=1 /\ fault(P0,x,MMU:Translation) /\ ~fault(P1,x)) \/ (0:X2=1 /\ 1:X5=1 /\ [x]=1 /\ fault(P0,x,MMU:Translation) /\ fault(P1,x,MMU:Translation)) \/ (0:X2=1 /\ 1:X5=1 /\ [x]=1 /\ fault(P1,x,MMU:Translation) /\ ~fault(P0,x)) \/ (0:X2=1 /\ 1:X5=2 /\ [x]=2 /\ ~fault(P0,x) /\ ~fault(P1,x)) \/ (0:X2=1 /\ 1:X5=2 /\ [x]=2 /\ fault(P0,x,MMU:Translation) /\ ~fault(P1,x)) \/ (0:X2=1 /\ 1:X5=2 /\ [x]=2 /\ fault(P0,x,MMU:Translation) /\ fault(P1,x,MMU:Translation)) \/ (0:X2=1 /\ 1:X5=2 /\ [x]=2 /\ fault(P1,x,MMU:Translation) /\ ~fault(P0,x)) \/ (0:X2=1 /\ 1:X5=4 /\ [x]=1 /\ fault(P0,x,MMU:Translation) /\ fault(P1,x,MMU:Translation)) \/ (0:X2=2 /\ 1:X5=2 /\ [x]=2 /\ ~fault(P0,x) /\ ~fault(P1,x)) \/ (0:X2=2 /\ 1:X5=2 /\ [x]=2 /\ fault(P0,x,MMU:Translation) /\ ~fault(P1,x)) \/ (0:X2=2 /\ 1:X5=2 /\ [x]=2 /\ fault(P0,x,MMU:Translation) /\ fault(P1,x,MMU:Translation)) \/ (0:X2=2 /\ 1:X5=2 /\ [x]=2 /\ fault(P1,x,MMU:Translation) /\ ~fault(P0,x)) \/ (0:X2=2 /\ 1:X5=4 /\ [x]=2 /\ fault(P0,x,MMU:Translation) /\ ~fault(P1,x)) \/ (0:X2=2 /\ 1:X5=4 /\ [x]=2 /\ fault(P0,x,MMU:Translation) /\ fault(P1,x,MMU:Translation)) \/ (0:X2=4 /\ 1:X5=1 /\ [x]=1 /\ ~fault(P0,x) /\ ~fault(P1,x)) \/ (0:X2=4 /\ 1:X5=1 /\ [x]=1 /\ fault(P0,x,MMU:Translation) /\ ~fault(P1,x)) \/ (0:X2=4 /\ 1:X5=1 /\ [x]=1 /\ fault(P0,x,MMU:Translation) /\ fault(P1,x,MMU:Translation)) \/ (0:X2=4 /\ 1:X5=1 /\ [x]=1 /\ fault(P1,x,MMU:Translation) /\ ~fault(P0,x)) \/ (0:X2=4 /\ 1:X5=2 /\ [x]=2 /\ ~fault(P0,x) /\ ~fault(P1,x)) \/ (0:X2=4 /\ 1:X5=2 /\ [x]=2 /\ fault(P0,x,MMU:Translation) /\ ~fault(P1,x)) \/ (0:X2=4 /\ 1:X5=2 /\ [x]=2 /\ fault(P0,x,MMU:Translation) /\ fault(P1,x,MMU:Translation)) \/ (0:X2=4 /\ 1:X5=2 /\ [x]=2 /\ fault(P1,x,MMU:Translation) /\ ~fault(P0,x))
