AArch64 R+tlbi-sync.ishsptevapteoa.va+tlbi-sync.ishsWptevapteoa.va-pospteoa.vap
"TLBI-sync.ISHsWWPteVAPteOA.VA CoePteOA.VAPteVA TLBI-sync.ISHsWWPteVAPteOA.VA PosWRPteOA.VAP FrePPteVA"
Variant=imprecise
Cycle=FrePPteVA TLBI-sync.ISHsWWPteVAPteOA.VA CoePteOA.VAPteVA TLBI-sync.ISHsWWPteVAPteOA.VA PosWRPteOA.VAP
Relax=[PteVA,TLBI-sync.ISHsWW,PteOA,PteVA]
Safe=Fre Coe PosWR
Generator=diy7 (version 7.56+02~dev)
Com=Co Fr
Orig=TLBI-sync.ISHsWWPteVAPteOA.VA CoePteOA.VAPteVA TLBI-sync.ISHsWWPteVAPteOA.VA PosWRPteOA.VAP FrePPteVA
pteval_t 0:X5;
int x=0; int y=4;
0:X0=PTE(x); 0:X1=(oa:PA(x), valid:0); 0:X2=(oa:PA(y)); 0:X3=x;
1:X0=PTE(x); 1:X1=(oa:PA(y), valid:0); 1:X2=(oa:PA(y)); 1:X3=x;
P0 | P1 ;
STR X1,[X0] | STR X1,[X0] ;
LSR X4,X3,#12 | LSR X5,X3,#12 ;
DSB ISH | DSB ISH ;
TLBI VAAE1IS,X4 | TLBI VAAE1IS,X5 ;
DSB ISH | DSB ISH ;
STR X2,[X0] | STR X2,[X0] ;
LDR X5,[X0] | LDR W4,[X3] ;
exists (0:X5=(oa:PA(y)) /\ 1:X4=0 /\ ~fault(P1,x)) \/ (0:X5=(oa:PA(y)) /\ 1:X4=0 /\ fault(P1,x,MMU:Translation))
