Test R+pos+tlbi-sync.ishsWptevapteoa.va-pospteoa.vap
AArch64 R+pos+tlbi-sync.ishsWptevapteoa.va-pospteoa.vap
"PosWW CoePPteVA TLBI-sync.ISHsWWPteVAPteOA.VA PosWRPteOA.VAP Fre"
Variant=imprecise
Cycle=Fre PosWW CoePPteVA TLBI-sync.ISHsWWPteVAPteOA.VA PosWRPteOA.VAP
Relax=[PteVA,TLBI-sync.ISHsWW,PteOA,PteVA]
Safe=Fre Coe PosWW PosWR
Generator=diy7 (version 7.56+02~dev)
Com=Co Fr
Orig=PosWW CoePPteVA TLBI-sync.ISHsWWPteVAPteOA.VA PosWRPteOA.VAP Fre
{ int x=0; int y=4;
0:X1=x;
1:X0=PTE(x); 1:X1=(oa:PA(x), valid:0); 1:X2=(oa:PA(y)); 1:X3=x;
 P0          | P1              ;
 MOV W0,#1   | STR X1,[X0]     ;
 STR W0,[X1] | LSR X5,X3,#12   ;
 MOV W2,#2   | DSB ISH         ;
 STR W2,[X1] | TLBI VAAE1IS,X5 ;
             | DSB ISH         ;
             | STR X2,[X0]     ;
             | LDR W4,[X3]     ;
exists (1:X4=0 /\ [x]=0 /\ ~fault(P0,x) /\ ~fault(P1,x)) \/ (1:X4=0 /\ [x]=0 /\ fault(P0,x,MMU:Translation) /\ ~fault(P1,x)) \/ (1:X4=0 /\ [x]=0 /\ fault(P0,x,MMU:Translation) /\ fault(P1,x,MMU:Translation)) \/ (1:X4=0 /\ [x]=0 /\ fault(P1,x,MMU:Translation) /\ ~fault(P0,x)) \/ (1:X4=1 /\ [x]=1 /\ ~fault(P0,x) /\ ~fault(P1,x)) \/ (1:X4=1 /\ [x]=1 /\ fault(P0,x,MMU:Translation) /\ ~fault(P1,x)) \/ (1:X4=1 /\ [x]=1 /\ fault(P0,x,MMU:Translation) /\ fault(P1,x,MMU:Translation)) \/ (1:X4=1 /\ [x]=1 /\ fault(P1,x,MMU:Translation) /\ ~fault(P0,x)) \/ (1:X4=2 /\ [x]=2 /\ ~fault(P0,x) /\ ~fault(P1,x)) \/ (1:X4=2 /\ [x]=2 /\ fault(P0,x,MMU:Translation) /\ ~fault(P1,x)) \/ (1:X4=2 /\ [x]=2 /\ fault(P0,x,MMU:Translation) /\ fault(P1,x,MMU:Translation)) \/ (1:X4=2 /\ [x]=2 /\ fault(P1,x,MMU:Translation) /\ ~fault(P0,x)) \/ (1:X4=4 /\ [x]=2 /\ fault(P0,x,MMU:Translation) /\ fault(P1,x,MMU:Translation))
