AArch64 MP+tlbi-sync.ishsWptevapteoa.va-isbsWpteoa.vap-pos+pos
"TLBI-sync.ISHsWWPteVAPteOA.VA ISBsWWPteOA.VAP PosWW Rfe PosRR FrePPteVA"
Variant=imprecise
Cycle=Rfe PosRR FrePPteVA TLBI-sync.ISHsWWPteVAPteOA.VA ISBsWWPteOA.VAP PosWW
Relax=[PteVA,TLBI-sync.ISHsWW,PteOA,PteVA,ISBsWW]
Safe=Rfe Fre PosWW PosRR
Generator=diy7 (version 7.56+02~dev)
Com=Rf Fr
Orig=TLBI-sync.ISHsWWPteVAPteOA.VA ISBsWWPteOA.VAP PosWW Rfe PosRR FrePPteVA
{ int x=0; int y=4;
0:X0=PTE(x); 0:X1=(oa:PA(x), valid:0); 0:X2=(oa:PA(y)); 0:X4=x;
1:X0=x;
P0 | P1 ;
STR X1,[X0] | LDR W1,[X0] ;
LSR X6,X4,#12 | LDR W2,[X0] ;
DSB ISH | ;
TLBI VAAE1IS,X6 | ;
DSB ISH | ;
STR X2,[X0] | ;
ISB | ;
MOV W3,#1 | ;
STR W3,[X4] | ;
MOV W5,#2 | ;
STR W5,[X4] | ;
exists (1:X1=0 /\ 1:X2=0 /\ [x]=0 /\ fault(P0,x,MMU:Translation) /\ fault(P1,x,MMU:Translation))
