Test MP+posWppteva-tlbi-sync.ishsWptevapteoa.va-pospteoa.vap+pos
AArch64 MP+posWppteva-tlbi-sync.ishsWptevapteoa.va-pospteoa.vap+pos
"PosWWPPteVA TLBI-sync.ISHsWWPteVAPteOA.VA PosWWPteOA.VAP Rfe PosRR Fre"
Variant=imprecise
Cycle=Rfe PosRR Fre PosWWPPteVA TLBI-sync.ISHsWWPteVAPteOA.VA PosWWPteOA.VAP
Relax=[PteVA,TLBI-sync.ISHsWW,PteOA,PteVA]
Safe=Rfe Fre PosWW PosRR
Generator=diy7 (version 7.56+02~dev)
Com=Rf Fr
Orig=PosWWPPteVA TLBI-sync.ISHsWWPteVAPteOA.VA PosWWPteOA.VAP Rfe PosRR Fre
{ int x=0; int y=4;
0:X1=x; 0:X2=PTE(x); 0:X3=(oa:PA(x), valid:0); 0:X4=(oa:PA(y));
1:X0=x;
 P0              | P1          ;
 MOV W0,#1       | LDR W1,[X0] ;
 STR W0,[X1]     | LDR W2,[X0] ;
 STR X3,[X2]     |             ;
 LSR X6,X1,#12   |             ;
 DSB ISH         |             ;
 TLBI VAAE1IS,X6 |             ;
 DSB ISH         |             ;
 STR X4,[X2]     |             ;
 MOV W5,#2       |             ;
 STR W5,[X1]     |             ;
exists (1:X1=0 /\ 1:X2=0 /\ [x]=1 /\ fault(P0,x,MMU:Translation) /\ fault(P1,x,MMU:Translation)) \/ (1:X1=0 /\ 1:X2=0 /\ [x]=1 /\ fault(P1,x,MMU:Translation) /\ ~fault(P0,x)) \/ (1:X1=0 /\ 1:X2=0 /\ [x]=2 /\ ~fault(P0,x) /\ ~fault(P1,x)) \/ (1:X1=0 /\ 1:X2=0 /\ [x]=2 /\ fault(P0,x,MMU:Translation) /\ ~fault(P1,x)) \/ (1:X1=0 /\ 1:X2=0 /\ [x]=2 /\ fault(P0,x,MMU:Translation) /\ fault(P1,x,MMU:Translation)) \/ (1:X1=0 /\ 1:X2=0 /\ [x]=2 /\ fault(P1,x,MMU:Translation) /\ ~fault(P0,x)) \/ (1:X1=0 /\ 1:X2=1 /\ [x]=1 /\ fault(P0,x,MMU:Translation) /\ fault(P1,x,MMU:Translation)) \/ (1:X1=0 /\ 1:X2=1 /\ [x]=1 /\ fault(P1,x,MMU:Translation) /\ ~fault(P0,x)) \/ (1:X1=0 /\ 1:X2=1 /\ [x]=2 /\ ~fault(P0,x) /\ ~fault(P1,x)) \/ (1:X1=0 /\ 1:X2=1 /\ [x]=2 /\ fault(P0,x,MMU:Translation) /\ ~fault(P1,x)) \/ (1:X1=0 /\ 1:X2=1 /\ [x]=2 /\ fault(P0,x,MMU:Translation) /\ fault(P1,x,MMU:Translation)) \/ (1:X1=0 /\ 1:X2=1 /\ [x]=2 /\ fault(P1,x,MMU:Translation) /\ ~fault(P0,x)) \/ (1:X1=0 /\ 1:X2=4 /\ [x]=2 /\ ~fault(P0,x) /\ ~fault(P1,x)) \/ (1:X1=0 /\ 1:X2=4 /\ [x]=2 /\ fault(P0,x,MMU:Translation) /\ ~fault(P1,x)) \/ (1:X1=0 /\ 1:X2=4 /\ [x]=2 /\ fault(P0,x,MMU:Translation) /\ fault(P1,x,MMU:Translation)) \/ (1:X1=0 /\ 1:X2=4 /\ [x]=2 /\ fault(P1,x,MMU:Translation) /\ ~fault(P0,x)) \/ (1:X1=1 /\ 1:X2=1 /\ [x]=1 /\ fault(P0,x,MMU:Translation) /\ fault(P1,x,MMU:Translation)) \/ (1:X1=1 /\ 1:X2=1 /\ [x]=2 /\ ~fault(P0,x) /\ ~fault(P1,x)) \/ (1:X1=1 /\ 1:X2=1 /\ [x]=2 /\ fault(P0,x,MMU:Translation) /\ ~fault(P1,x)) \/ (1:X1=1 /\ 1:X2=1 /\ [x]=2 /\ fault(P0,x,MMU:Translation) /\ fault(P1,x,MMU:Translation)) \/ (1:X1=1 /\ 1:X2=1 /\ [x]=2 /\ fault(P1,x,MMU:Translation) /\ ~fault(P0,x)) \/ (1:X1=1 /\ 1:X2=4 /\ [x]=2 /\ ~fault(P0,x) /\ ~fault(P1,x)) \/ (1:X1=1 /\ 1:X2=4 /\ [x]=2 /\ fault(P0,x,MMU:Translation) /\ ~fault(P1,x)) \/ (1:X1=1 /\ 1:X2=4 /\ [x]=2 /\ fault(P0,x,MMU:Translation) /\ fault(P1,x,MMU:Translation)) \/ (1:X1=1 /\ 1:X2=4 /\ [x]=2 /\ fault(P1,x,MMU:Translation) /\ ~fault(P0,x)) \/ (1:X1=4 /\ 1:X2=4 /\ [x]=2 /\ ~fault(P0,x) /\ ~fault(P1,x)) \/ (1:X1=4 /\ 1:X2=4 /\ [x]=2 /\ fault(P0,x,MMU:Translation) /\ ~fault(P1,x)) \/ (1:X1=4 /\ 1:X2=4 /\ [x]=2 /\ fault(P0,x,MMU:Translation) /\ fault(P1,x,MMU:Translation)) \/ (1:X1=4 /\ 1:X2=4 /\ [x]=2 /\ fault(P1,x,MMU:Translation) /\ ~fault(P0,x))
