Test IRIW-V2Ipte+64
AArch64 IRIW-V2Ipte+64
0:X10=pte_x; 3:X10=pte_x;
0:X1=(oa:phy_y,valid:1);
3:X2=(oa:phy_z,valid:0);
1:X4=x; 2:X4=x;
int64_t x;
int64_t y=1; int64_t z=2;
int64_t 1:X5; int64_t 2:X6;
P0           | P1              | P2              | P3          ;
STR X1,[X10] | LDR X5,[X4]     | L1: LDR X5,[X4] | STR X2,[X10];
             | L0: LDR X6,[X4] | LDR X6,[X4]     |             ;
exists (1:X5=0 /\ 2:X6=0 /\ [PTE(x)]=(oa:PA(y)) /\ fault(P1:L0,x,MMU:Translation) /\ fault(P2:L1,x,MMU:Translation)) \/ (1:X5=0 /\ 2:X6=0 /\ [PTE(x)]=(oa:PA(z), valid:0) /\ fault(P1:L0,x,MMU:Translation) /\ fault(P2:L1,x,MMU:Translation)) \/ (1:X5=0 /\ 2:X6=1 /\ [PTE(x)]=(oa:PA(y)) /\ fault(P1:L0,x,MMU:Translation) /\ ~fault(P2:L1,x)) \/ (1:X5=0 /\ 2:X6=1 /\ [PTE(x)]=(oa:PA(z), valid:0) /\ fault(P1:L0,x,MMU:Translation) /\ ~fault(P2:L1,x)) \/ (1:X5=1 /\ 2:X6=0 /\ [PTE(x)]=(oa:PA(y)) /\ fault(P1:L0,x,MMU:Translation) /\ ~fault(P2:L1,x)) \/ (1:X5=1 /\ 2:X6=0 /\ [PTE(x)]=(oa:PA(y)) /\ fault(P1:L0,x,MMU:Translation) /\ fault(P2:L1,x,MMU:Translation)) \/ (1:X5=1 /\ 2:X6=0 /\ [PTE(x)]=(oa:PA(z), valid:0) /\ fault(P1:L0,x,MMU:Translation) /\ ~fault(P2:L1,x)) \/ (1:X5=1 /\ 2:X6=0 /\ [PTE(x)]=(oa:PA(z), valid:0) /\ fault(P1:L0,x,MMU:Translation) /\ fault(P2:L1,x,MMU:Translation)) \/ (1:X5=1 /\ 2:X6=1 /\ [PTE(x)]=(oa:PA(y)) /\ fault(P1:L0,x,MMU:Translation) /\ ~fault(P2:L1,x)) \/ (1:X5=1 /\ 2:X6=1 /\ [PTE(x)]=(oa:PA(z), valid:0) /\ fault(P1:L0,x,MMU:Translation) /\ ~fault(P2:L1,x))
