Test IRIW-I2Ipte+64
AArch64 IRIW-I2Ipte+64
0:X10=pte_x; 3:X10=pte_x;
0:X1=(oa:phy_y,valid:0);
3:X2=(oa:phy_z,valid:0);
1:X4=x; 2:X4=x;
int64_t x;
int64_t y=1; int64_t z=2;
P0           | P1               | P2               | P3          ;
STR X1,[X10] | L10: LDR X5,[X4] | L21: LDR X5,[X4] | STR X2,[X10];
             | L11: LDR X6,[X4] | L22: LDR X6,[X4] |             ;
exists ([PTE(x)]=(oa:PA(y), valid:0) /\ fault(P1:L10,x,MMU:Translation) /\ fault(P2:L22,x,MMU:Translation) /\ ~fault(P1:L11,x) /\ ~fault(P2:L21,x)) \/ ([PTE(x)]=(oa:PA(y), valid:0) /\ fault(P1:L11,x,MMU:Translation) /\ fault(P2:L22,x,MMU:Translation) /\ ~fault(P1:L10,x) /\ ~fault(P2:L21,x)) \/ ([PTE(x)]=(oa:PA(z), valid:0) /\ fault(P1:L10,x,MMU:Translation) /\ fault(P2:L22,x,MMU:Translation) /\ ~fault(P1:L11,x) /\ ~fault(P2:L21,x)) \/ ([PTE(x)]=(oa:PA(z), valid:0) /\ fault(P1:L11,x,MMU:Translation) /\ fault(P2:L21,x,MMU:Translation) /\ ~fault(P1:L10,x) /\ ~fault(P2:L22,x)) \/ ([PTE(x)]=(oa:PA(z), valid:0) /\ fault(P1:L11,x,MMU:Translation) /\ fault(P2:L22,x,MMU:Translation) /\ ~fault(P1:L10,x) /\ ~fault(P2:L21,x))
