AArch64 2+2W+tlbi-sync.ishsptevapteoa.va+posWppteva-tlbi-sync.ishsWptevapteoa.va-pospteoa.vap
"TLBI-sync.ISHsWWPteVAPteOA.VA CoePteOA.VAP PosWWPPteVA TLBI-sync.ISHsWWPteVAPteOA.VA PosWWPteOA.VAP CoePPteVA"
Variant=imprecise
Cycle=CoePPteVA TLBI-sync.ISHsWWPteVAPteOA.VA CoePteOA.VAP PosWWPPteVA TLBI-sync.ISHsWWPteVAPteOA.VA PosWWPteOA.VAP
Relax=[PteVA,TLBI-sync.ISHsWW,PteOA,PteVA]
Safe=Coe PosWW
Generator=diy7 (version 7.56+02~dev)
Com=Co Co
Orig=TLBI-sync.ISHsWWPteVAPteOA.VA CoePteOA.VAP PosWWPPteVA TLBI-sync.ISHsWWPteVAPteOA.VA PosWWPteOA.VAP CoePPteVA
pteval_t 0:X5;
int x=0; int y=4;
0:X0=PTE(x); 0:X1=(oa:PA(x), valid:0); 0:X2=(oa:PA(y)); 0:X3=x;
1:X1=x; 1:X2=PTE(x); 1:X3=(oa:PA(y), valid:0); 1:X4=(oa:PA(y));
P0 | P1 ;
STR X1,[X0] | MOV W0,#1 ;
LSR X4,X3,#12 | STR W0,[X1] ;
DSB ISH | STR X3,[X2] ;
TLBI VAAE1IS,X4 | LSR X6,X1,#12 ;
DSB ISH | DSB ISH ;
STR X2,[X0] | TLBI VAAE1IS,X6 ;
LDR X5,[X0] | DSB ISH ;
| STR X4,[X2] ;
| MOV W5,#2 ;
| STR W5,[X1] ;
exists (0:X5=(oa:PA(y)) /\ [x]=2 /\ ~fault(P1,x)) \/ (0:X5=(oa:PA(y)) /\ [x]=2 /\ fault(P1,x,MMU:Translation)) \/ (0:X5=(oa:PA(y), valid:0) /\ [x]=1 /\ ~fault(P1,x)) \/ (0:X5=(oa:PA(y), valid:0) /\ [x]=1 /\ fault(P1,x,MMU:Translation))
