AArch64 WRW+WR+pos+tlbi-sync.ishsWptevapteoa.va-pospteoa.vap "Rfe PosRW CoePPteVA TLBI-sync.ISHsWWPteVAPteOA.VA PosWRPteOA.VAP Fre" Variant=imprecise Cycle=Rfe PosRW CoePPteVA TLBI-sync.ISHsWWPteVAPteOA.VA PosWRPteOA.VAP Fre Relax=[PteVA,TLBI-sync.ISHsWW,PteOA,PteVA] Safe=Rfe Fre Coe PosWR PosRW Generator=diy7 (version 7.56+02~dev) Com=Rf Co Fr Orig=Rfe PosRW CoePPteVA TLBI-sync.ISHsWWPteVAPteOA.VA PosWRPteOA.VAP Fre { int x=0; int y=4; 0:X1=x; 1:X0=x; 2:X0=PTE(x); 2:X1=(oa:PA(x), valid:0); 2:X2=(oa:PA(y)); 2:X3=x; } P0 | P1 | P2 ; MOV W0,#1 | LDR W1,[X0] | STR X1,[X0] ; STR W0,[X1] | MOV W2,#2 | LSR X5,X3,#12 ; | STR W2,[X0] | DSB ISH ; | | TLBI VAAE1IS,X5 ; | | DSB ISH ; | | STR X2,[X0] ; | | LDR W4,[X3] ; exists (1:X1=0 /\ 2:X4=2 /\ [x]=0 /\ fault(P0,x,MMU:Translation) /\ ~fault(P1,x) /\ ~fault(P2,x)) \/ (1:X1=0 /\ 2:X4=4 /\ [x]=0 /\ fault(P2,x,MMU:Translation) /\ ~fault(P0,x) /\ ~fault(P1,x))
