AArch64 R+tlbi-sync.ishsWptevapteoa.va-isbsWpteoa.vapteva-tlbi-sync.ishsptevapteoa.va+tlbi-sync.ishsWptevapteoa.va-isbspteoa.vap
"TLBI-sync.ISHsWWPteVAPteOA.VA ISBsWWPteOA.VAPteVA TLBI-sync.ISHsWWPteVAPteOA.VA CoePteOA.VAPteVA TLBI-sync.ISHsWWPteVAPteOA.VA ISBsWRPteOA.VAP FrePPteVA"
Variant=imprecise
Cycle=FrePPteVA TLBI-sync.ISHsWWPteVAPteOA.VA ISBsWWPteOA.VAPteVA TLBI-sync.ISHsWWPteVAPteOA.VA CoePteOA.VAPteVA TLBI-sync.ISHsWWPteVAPteOA.VA ISBsWRPteOA.VAP
Relax=[PteVA,TLBI-sync.ISHsWW,PteOA,PteVA] [PteVA,TLBI-sync.ISHsWW,PteOA,PteVA,ISBsWW] [PteVA,TLBI-sync.ISHsWW,PteOA,PteVA,ISBsWR]
Safe=Fre Coe
Generator=diy7 (version 7.56+02~dev)
Com=Co Fr
Orig=TLBI-sync.ISHsWWPteVAPteOA.VA ISBsWWPteOA.VAPteVA TLBI-sync.ISHsWWPteVAPteOA.VA CoePteOA.VAPteVA TLBI-sync.ISHsWWPteVAPteOA.VA ISBsWRPteOA.VAP FrePPteVA
pteval_t 0:X6;
int x=0; int y=4;
0:X0=PTE(x); 0:X1=(oa:PA(x), valid:0); 0:X2=(oa:PA(y)); 0:X3=(oa:PA(y), valid:0); 0:X4=x;
1:X0=PTE(x); 1:X1=(oa:PA(y), valid:0); 1:X2=(oa:PA(y)); 1:X3=x;
P0 | P1 ;
STR X1,[X0] | STR X1,[X0] ;
LSR X5,X4,#12 | LSR X5,X3,#12 ;
DSB ISH | DSB ISH ;
TLBI VAAE1IS,X5 | TLBI VAAE1IS,X5 ;
DSB ISH | DSB ISH ;
STR X2,[X0] | STR X2,[X0] ;
ISB | ISB ;
STR X3,[X0] | LDR W4,[X3] ;
LSR X5,X4,#12 | ;
DSB ISH | ;
TLBI VAAE1IS,X5 | ;
DSB ISH | ;
STR X2,[X0] | ;
LDR X6,[X0] | ;
exists (0:X6=(oa:PA(y), valid:0) /\ 1:X4=4 /\ fault(P1,x,MMU:Translation))
