AArch64 Artem3+TLBIVMALL+dmb.sy+dmb.ld { 0:X1 = pte_x; 0:X2 = (oa:phy_x,valid:0); 0:X3 = x; 0:X4 = y; 0:X5 = 1; 0:X6 = z; 1:X0 = (oa:phy_y,valid:0); 1:X1 = pte_y; 1:X3 = x; 2:X1 = z; 2:X3 = y; } P0 | P1 | P2 ; STR X2,[X1] | STR X0,[X1] | LDR W0,[X1] ; DSB ISH | DMB ISH | DMB LD ; TLBI VMALLE1IS |L1: |L2: ; DSB ISH | LDR W2,[X3] | LDR W2,[X3] ; STR W5,[X6] | | ; exists (2:X0=1 /\ ~fault(P1:L1,x) /\ ~fault(P2:L2,y))
