AArch64 WRR+2W+pos+tlbi-sync.ishsWptevapteoa.va-pospteoa.vap "Rfe PosRR FrePPteVA TLBI-sync.ISHsWWPteVAPteOA.VA PosWWPteOA.VAP Coe" Variant=imprecise Cycle=Rfe PosRR FrePPteVA TLBI-sync.ISHsWWPteVAPteOA.VA PosWWPteOA.VAP Coe Relax=[PteVA,TLBI-sync.ISHsWW,PteOA,PteVA] Safe=Rfe Fre Coe PosWW PosRR Generator=diy7 (version 7.56+02~dev) Com=Rf Fr Co Orig=Rfe PosRR FrePPteVA TLBI-sync.ISHsWWPteVAPteOA.VA PosWWPteOA.VAP Coe { int x=0; int y=4; 0:X1=x; 1:X0=x; 2:X0=PTE(x); 2:X1=(oa:PA(x), valid:0); 2:X2=(oa:PA(y)); 2:X4=x; } P0 | P1 | P2 ; MOV W0,#1 | LDR W1,[X0] | STR X1,[X0] ; STR W0,[X1] | LDR W2,[X0] | LSR X5,X4,#12 ; | | DSB ISH ; | | TLBI VAAE1IS,X5 ; | | DSB ISH ; | | STR X2,[X0] ; | | MOV W3,#2 ; | | STR W3,[X4] ; exists (1:X1=0 /\ 1:X2=0 /\ [x]=1 /\ fault(P0,x) /\ ~fault(P1,x) /\ ~fault(P2,x))
