AArch64 SB+pos+tlbi-sync.ishsWptevapteoa.va-isbsWpteoa.vap-pos
"PosWR FrePPteVA TLBI-sync.ISHsWWPteVAPteOA.VA ISBsWWPteOA.VAP PosWR Fre"
Variant=imprecise
Cycle=Fre PosWR FrePPteVA TLBI-sync.ISHsWWPteVAPteOA.VA ISBsWWPteOA.VAP PosWR
Relax=[PteVA,TLBI-sync.ISHsWW,PteOA,PteVA,ISBsWW]
Safe=Fre PosWR
Generator=diy7 (version 7.56+02~dev)
Com=Fr Fr
Orig=PosWR FrePPteVA TLBI-sync.ISHsWWPteVAPteOA.VA ISBsWWPteOA.VAP PosWR Fre
{ int x=0; int y=4;
0:X1=x;
1:X0=PTE(x); 1:X1=(oa:PA(x), valid:0); 1:X2=(oa:PA(y)); 1:X4=x;
P0 | P1 ;
MOV W0,#1 | STR X1,[X0] ;
STR W0,[X1] | LSR X6,X4,#12 ;
LDR W2,[X1] | DSB ISH ;
| TLBI VAAE1IS,X6 ;
| DSB ISH ;
| STR X2,[X0] ;
| ISB ;
| MOV W3,#2 ;
| STR W3,[X4] ;
| LDR W5,[X4] ;
exists (0:X2=1 /\ 1:X5=2 /\ [x]=1 /\ fault(P0,x) /\ ~fault(P1,x))
