AArch64 MP+tlbi-sync.ishsWptevapteoa.va-isbsWpteoa.vapteva-tlbi-sync.ishsptevapteoa.va+pos
"TLBI-sync.ISHsWWPteVAPteOA.VA ISBsWWPteOA.VAPteVA TLBI-sync.ISHsWWPteVAPteOA.VA RfePteOA.VAP PosRR FrePPteVA"
Variant=imprecise
Cycle=PosRR FrePPteVA TLBI-sync.ISHsWWPteVAPteOA.VA ISBsWWPteOA.VAPteVA TLBI-sync.ISHsWWPteVAPteOA.VA RfePteOA.VAP
Relax=[PteVA,TLBI-sync.ISHsWW,PteOA,PteVA] [PteVA,TLBI-sync.ISHsWW,PteOA,PteVA,ISBsWW]
Safe=Rfe Fre PosRR
Generator=diy7 (version 7.56+02~dev)
Com=Rf Fr
Orig=TLBI-sync.ISHsWWPteVAPteOA.VA ISBsWWPteOA.VAPteVA TLBI-sync.ISHsWWPteVAPteOA.VA RfePteOA.VAP PosRR FrePPteVA
{ int x=0; int y=4;
0:X0=PTE(x); 0:X1=(oa:PA(x), valid:0); 0:X2=(oa:PA(y)); 0:X3=(oa:PA(y), valid:0); 0:X4=x;
1:X0=x;
P0 | P1 ;
STR X1,[X0] | LDR W1,[X0] ;
LSR X5,X4,#12 | LDR W2,[X0] ;
DSB ISH | ;
TLBI VAAE1IS,X5 | ;
DSB ISH | ;
STR X2,[X0] | ;
ISB | ;
STR X3,[X0] | ;
LSR X5,X4,#12 | ;
DSB ISH | ;
TLBI VAAE1IS,X5 | ;
DSB ISH | ;
STR X2,[X0] | ;
exists (1:X1=0 /\ 1:X2=0 /\ fault(P1,x))
