AArch64 coRR+W-DSB-TLBI-DSB-HU+rfe-W TTHM=HD { pte_z=(dbm:1,db:0); y=1; 0:X1=x; 1:X3=pte_x; 1:X0=(oa:phy_x,valid:0); 1:X1=x; 1:X5=1; 1:X6=z; 2:X6=pte_z; 2:X3=pte_x; 2:X4=(oa:phy_y); } P0 | P1 | P2 ; L1:LDR W2,[X1] | STR X0,[X3] | LDR X0,[X6] ; L0:LDR W4,[X1] | DSB ISH | DMB ISH ; | LSR X9,X1,#12 | STR X4,[X3] ; | TLBI VAAE1IS,X9 | ; | DSB ISH | ; | STR W5,[X6] | ; exists (0:X2=1 /\ 0:X4=0 /\ 2:X0=(oa:PA(z), dbm:1, db:0) /\ ~fault(P0:L0,x)) \/ (0:X2=1 /\ 0:X4=0 /\ 2:X0=(oa:PA(z), dbm:1, db:0) /\ fault(P0:L0,x,MMU:Translation))
