AArch64 WRW+WR+posWppteva-tlbi-sync.ishsptevapteoa.va+pos "Rfe PosRWPPteVA TLBI-sync.ISHsWWPteVAPteOA.VA CoePteOA.VAP PosWR Fre" Variant=imprecise Cycle=Rfe PosRWPPteVA TLBI-sync.ISHsWWPteVAPteOA.VA CoePteOA.VAP PosWR Fre Relax=[PteVA,TLBI-sync.ISHsWW,PteOA,PteVA] Safe=Rfe Fre Coe PosWR PosRW Generator=diy7 (version 7.56+02~dev) Com=Rf Co Fr Orig=Rfe PosRWPPteVA TLBI-sync.ISHsWWPteVAPteOA.VA CoePteOA.VAP PosWR Fre { int x=0; int y=4; 0:X1=x; 1:X0=x; 1:X2=PTE(x); 1:X3=(oa:PA(x), valid:0); 1:X4=(oa:PA(y)); 2:X1=x; } P0 | P1 | P2 ; MOV W0,#1 | LDR W1,[X0] | MOV W0,#2 ; STR W0,[X1] | STR X3,[X2] | STR W0,[X1] ; | LSR X5,X0,#12 | LDR W2,[X1] ; | DSB ISH | ; | TLBI VAAE1IS,X5 | ; | DSB ISH | ; | STR X4,[X2] | ; exists (1:X1=0 /\ 2:X2=1 /\ [x]=0 /\ fault(P0,x,MMU:Translation) /\ ~fault(P1,x) /\ ~fault(P2,x))
