AArch64 WRR+2W+pos+posWppteva-tlbi-sync.ishsptevapteoa.va "Rfe PosRR Fre PosWWPPteVA TLBI-sync.ISHsWWPteVAPteOA.VA CoePteOA.VAP" Variant=imprecise Cycle=Rfe PosRR Fre PosWWPPteVA TLBI-sync.ISHsWWPteVAPteOA.VA CoePteOA.VAP Relax=[PteVA,TLBI-sync.ISHsWW,PteOA,PteVA] Safe=Rfe Fre Coe PosWW PosRR Generator=diy7 (version 7.56+02~dev) Com=Rf Fr Co Orig=Rfe PosRR Fre PosWWPPteVA TLBI-sync.ISHsWWPteVAPteOA.VA CoePteOA.VAP { int x=0; int y=4; 0:X1=x; 1:X0=x; 2:X1=x; 2:X2=PTE(x); 2:X3=(oa:PA(x), valid:0); 2:X4=(oa:PA(y)); } P0 | P1 | P2 ; MOV W0,#1 | LDR W1,[X0] | MOV W0,#2 ; STR W0,[X1] | LDR W2,[X0] | STR W0,[X1] ; | | STR X3,[X2] ; | | LSR X5,X1,#12 ; | | DSB ISH ; | | TLBI VAAE1IS,X5 ; | | DSB ISH ; | | STR X4,[X2] ; exists (1:X1=4 /\ 1:X2=1 /\ [x]=2 /\ fault(P0,x,MMU:Translation) /\ ~fault(P1,x) /\ ~fault(P2,x)) \/ (1:X1=4 /\ 1:X2=1 /\ [x]=2 /\ fault(P1,x,MMU:Translation) /\ ~fault(P0,x) /\ ~fault(P2,x))
