Executions for behaviour:
"1:R0=0 ; 1:R1=1 ; 1:R3=2 ; 1:R4=0"
"1:R0=1 ; 1:R1=1 ; 1:R3=2 ; 1:R4=0"
ARM DETOUR0676
"DMBdWW Rfe PosRR Fri Rfi DpCtrlIsbdR Fre"
Cycle=Rfi DpCtrlIsbdR Fre DMBdWW Rfe PosRR Fri
Prefetch=0:x=F,0:y=W,1:y=F,1:x=T
Com=Rf Fr
Orig=DMBdWW Rfe PosRR Fri Rfi DpCtrlIsbdR Fre
%x0=x; %y0=y;
%y1=y; %x1=x;
P0 | P1 ;
MOV R0,#1 | LDR R0,[%y1] ;
STR R0,[%x0] | LDR R1,[%y1] ;
DMB | MOV R2,#2 ;
MOV R1,#1 | STR R2,[%y1] ;
STR R1,[%y0] | LDR R3,[%y1] ;
| CMP R3,R3 ;
| BNE LC00 ;
| LC00: ;
| ISB ;
| LDR R4,[%x1] ;
Observed
1:R0=0; 1:R1=1; 1:R3=2; 1:R4=0;
and 1:R0=1; 1:R1=1; 1:R3=2; 1:R4=0;
