ARM MP+PPO866
"Fre DMBdWW Rfe DpAddrdW PosWW PosWR PosRR DpAddrdR PosRR"
Cycle=Rfe DpAddrdW PosWW PosWR PosRR DpAddrdR PosRR Fre DMBdWW
Relax=
Safe=Rfe Fre PosWW PosWR PosRR DMBdWW DpAddrdW DpAddrdR
Prefetch=1:x=T
Orig=Fre DMBdWW Rfe DpAddrdW PosWW PosWR PosRR DpAddrdR PosRR
%x0=x; %y0=y;
%y1=y; %z1=z; %x1=x;
P0 | P1 ;
MOV R0, #1 | LDR R0, [%y1] ;
STR R0, [%x0] | EOR R1,R0,R0 ;
DMB | MOV R2, #1 ;
MOV R1, #1 | STR R2, [R1,%z1] ;
STR R1, [%y0] | MOV R3, #2 ;
| STR R3, [%z1] ;
| LDR R4, [%z1] ;
| LDR R5, [%z1] ;
| EOR R6,R5,R5 ;
| LDR R7, [R6,%x1] ;
| LDR R8, [%x1] ;
Observed
1:R0=1; 1:R8=0; z=2;
