ARM MP+PPO198
"Fre DMBdWW Rfe PosRR DpAddrdW PosWW PosWR PosRR DpAddrdR"
Cycle=Rfe PosRR DpAddrdW PosWW PosWR PosRR DpAddrdR Fre DMBdWW
Relax=
Safe=Rfe Fre PosWW PosWR PosRR DMBdWW DpAddrdW DpAddrdR
Prefetch=1:x=T
Orig=Fre DMBdWW Rfe PosRR DpAddrdW PosWW PosWR PosRR DpAddrdR
%x0=x; %y0=y;
%y1=y; %z1=z; %x1=x;
P0 | P1 ;
MOV R0, #1 | LDR R0, [%y1] ;
STR R0, [%x0] | LDR R1, [%y1] ;
DMB | EOR R2,R1,R1 ;
MOV R1, #1 | MOV R3, #1 ;
STR R1, [%y0] | STR R3, [R2,%z1] ;
| MOV R4, #2 ;
| STR R4, [%z1] ;
| LDR R5, [%z1] ;
| LDR R6, [%z1] ;
| EOR R7,R6,R6 ;
| LDR R8, [R7,%x1] ;
Observed
1:R0=1; 1:R8=0; z=2;
