ARM MP+PPO092 "Fre DMBdWW Rfe DpAddrdR DpAddrdW PosWW PosWR DpAddrdR" Cycle=Rfe DpAddrdR DpAddrdW PosWW PosWR DpAddrdR Fre DMBdWW Relax= Safe=Rfe Fre PosWW PosWR DMBdWW DpAddrdW DpAddrdR Prefetch=1:x=T Orig=Fre DMBdWW Rfe DpAddrdR DpAddrdW PosWW PosWR DpAddrdR { %x0=x; %y0=y; %y1=y; %z1=z; %a1=a; %x1=x; } P0 | P1 ; MOV R0, #1 | LDR R0, [%y1] ; STR R0, [%x0] | EOR R1,R0,R0 ; DMB | LDR R2, [R1,%z1] ; MOV R1, #1 | EOR R3,R2,R2 ; STR R1, [%y0] | MOV R4, #1 ; | STR R4, [R3,%a1] ; | MOV R5, #2 ; | STR R5, [%a1] ; | LDR R6, [%a1] ; | EOR R7,R6,R6 ; | LDR R8, [R7,%x1] ; Observed 1:R0=1; 1:R8=0; a=2;
