ARM LB+PPO0592
"PodRW Rfe DpDatadW Rfe PosRR PosRW PosWR PosRR"
Cycle=Rfe PosRR PosRW PosWR PosRR PodRW Rfe DpDatadW
Relax=
Safe=Rfe PosWR PosRW PosRR Pod*W DpDatadW
Prefetch=
Com=Rf Rf
Orig=PodRW Rfe DpDatadW Rfe PosRR PosRW PosWR PosRR
%y0=y; %x0=x;
%x1=x; %y1=y;
P0 | P1 ;
LDR R0,[%y0] | LDR R0,[%x1] ;
EOR R1,R0,R0 | LDR R1,[%x1] ;
ADD R1,R1,#1 | MOV R2,#2 ;
STR R1,[%x0] | STR R2,[%x1] ;
| LDR R3,[%x1] ;
| LDR R4,[%x1] ;
| MOV R5,#1 ;
| STR R5,[%y1] ;
Observed
0:R0=1; 1:R0=1; x=2;
