ARM LB+PPO0584
"PodRW Rfe DpDatadW Rfe DpDatadW PosWW PosWR PosRR"
Cycle=Rfe DpDatadW Rfe DpDatadW PosWW PosWR PosRR PodRW
Relax=
Safe=Rfe PosWW PosWR PosRR Pod*W DpDatadW
Prefetch=
Com=Rf Rf
Orig=PodRW Rfe DpDatadW Rfe DpDatadW PosWW PosWR PosRR
%z0=z; %x0=x;
%x1=x; %y1=y; %z1=z;
P0 | P1 ;
LDR R0,[%z0] | LDR R0,[%x1] ;
EOR R1,R0,R0 | EOR R1,R0,R0 ;
ADD R1,R1,#1 | ADD R1,R1,#1 ;
STR R1,[%x0] | STR R1,[%y1] ;
| MOV R2,#2 ;
| STR R2,[%y1] ;
| LDR R3,[%y1] ;
| LDR R4,[%y1] ;
| MOV R5,#1 ;
| STR R5,[%z1] ;
Observed
0:R0=1; 1:R0=1; y=2;
