ARM LB+PPO0139 "PodWW Rfe DpDatadW Rfe DpDatadW" Cycle=Rfe DpDatadW Rfe DpDatadW PodWW Relax= Safe=Rfe Pod*W DpDatadW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe DpDatadW { %z0=z; %x0=x; %x1=x; %y1=y; %z1=z; } P0 | P1 ; LDR R0,[%z0] | LDR R0,[%x1] ; EOR R1,R0,R0 | EOR R1,R0,R0 ; ADD R1,R1,#1 | ADD R1,R1,#1 ; STR R1,[%x0] | STR R1,[%y1] ; | MOV R2,#1 ; | STR R2,[%z1] ; Observed 0:R0=1; 1:R0=1;
