ARM DETOUR0203 "DpDatadW Rfe DpAddrdW DetourW Fri Rfe" Cycle=Rfe DpAddrdW DetourW Fri Rfe DpDatadW Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Rf Orig=DpDatadW Rfe DpAddrdW DetourW Fri Rfe { %x0=x; %y0=y; %y1=y; %x1=x; %x2=x; } P0 | P1 | P2 ; LDR R0,[%x0] | LDR R0,[%y1] | MOV R0,#2 ; EOR R1,R0,R0 | EOR R1,R0,R0 | STR R0,[%x2] ; ADD R1,R1,#1 | MOV R2,#1 | ; STR R1,[%y0] | STR R2,[R1,%x1] | ; | LDR R3,[%x1] | ; | MOV R4,#3 | ; | STR R4,[%x1] | ; Observed 0:R0=2; 1:R0=1; 1:R3=2;
