ARM 3.LB+dsb.st+po+addr "DSB.STdRW Rfe PodRW Rfe DpAddrdW Rfe" Cycle=Rfe PodRW Rfe DpAddrdW Rfe DSB.STdRW Prefetch=0:x=F,0:y=W,1:y=F,1:z=W,2:z=F,2:x=W Com=Rf Rf Rf Orig=DSB.STdRW Rfe PodRW Rfe DpAddrdW Rfe { %x0=x; %y0=y; %y1=y; %z1=z; %z2=z; %x2=x; } P0 | P1 | P2 ; LDR R0,[%x0] | LDR R0,[%y1] | LDR R0,[%z2] ; DSB ST | MOV R1,#1 | EOR R1,R0,R0 ; MOV R1,#1 | STR R1,[%z1] | MOV R2,#1 ; STR R1,[%y0] | | STR R2,[R1,%x2] ; Observed 0:R0=1; 1:R0=1; 2:R0=1;
