Test MP+dmb+addr-pos-fri-rfi
Executions for behaviour: "1:R0=0 ; 1:R2=2 ; 1:R3=0 ; 1:R5=1 ; x=1"
ARM MP+dmb+addr-pos-fri-rfi
"DMBdWW Rfe DpAddrdR PosRR Fri Rfi Fre"
Cycle=Rfi Fre DMBdWW Rfe DpAddrdR PosRR Fri
Prefetch=0:x=F,0:y=W,1:y=F,1:x=T
Com=Rf Fr
Orig=DMBdWW Rfe DpAddrdR PosRR Fri Rfi Fre
%x0=x; %y0=y;
%y1=y; %x1=x;
 P0           | P1              ;
 MOV R0,#2    | LDR R0,[%y1]    ;
 STR R0,[%x0] | EOR R1,R0,R0    ;
 DMB          | LDR R2,[R1,%x1] ;
 MOV R1,#1    | LDR R3,[%x1]    ;
 STR R1,[%y0] | MOV R4,#1       ;
              | STR R4,[%x1]    ;
              | LDR R5,[%x1]    ;
Observed
    1:R0=0; 1:R2=2; 1:R3=0; 1:R5=1; x=1;
