Executions for behaviour:
"1:R0=1 ; 1:R7=0"
ARM MP+PPO823
"Fre DMBdWW Rfe DpAddrdR DpCtrldW PosWR DpAddrdR PosRR"
Cycle=Rfe DpAddrdR DpCtrldW PosWR DpAddrdR PosRR Fre DMBdWW
Relax=
Safe=Rfe Fre PosWR PosRR DMBdWW DpAddrdR DpCtrldW
Prefetch=1:x=T
Orig=Fre DMBdWW Rfe DpAddrdR DpCtrldW PosWR DpAddrdR PosRR
%x0=x; %y0=y;
%y1=y; %z1=z; %a1=a; %x1=x;
P0 | P1 ;
MOV R0, #1 | LDR R0, [%y1] ;
STR R0, [%x0] | EOR R1,R0,R0 ;
DMB | LDR R2, [R1,%z1] ;
MOV R1, #1 | CMP R2, R2 ;
STR R1, [%y0] | BNE LC00 ;
| LC00: ;
| MOV R3, #1 ;
| STR R3, [%a1] ;
| LDR R4, [%a1] ;
| EOR R5,R4,R4 ;
| LDR R6, [R5,%x1] ;
| LDR R7, [%x1] ;
Observed
1:R0=1; 1:R7=0;
