Executions for behaviour:
"1:R0=0 ; 1:R1=0 ; 2:R0=0 ; 2:R2=0"
"1:R0=1 ; 1:R1=0 ; 2:R0=0 ; 2:R2=0"
"1:R0=0 ; 1:R1=1 ; 2:R0=0 ; 2:R2=0"
"1:R0=1 ; 1:R1=1 ; 2:R0=0 ; 2:R2=0"
"1:R0=0 ; 1:R1=0 ; 2:R0=1 ; 2:R2=0"
"1:R0=0 ; 1:R1=1 ; 2:R0=1 ; 2:R2=0"
"1:R0=0 ; 1:R1=0 ; 2:R0=0 ; 2:R2=1"
"1:R0=1 ; 1:R1=0 ; 2:R0=0 ; 2:R2=1"
"1:R0=0 ; 1:R1=1 ; 2:R0=0 ; 2:R2=1"
"1:R0=1 ; 1:R1=1 ; 2:R0=0 ; 2:R2=1"
"1:R0=0 ; 1:R1=0 ; 2:R0=1 ; 2:R2=1"
"1:R0=1 ; 1:R1=0 ; 2:R0=1 ; 2:R2=1"
"1:R0=0 ; 1:R1=1 ; 2:R0=1 ; 2:R2=1"
"1:R0=1 ; 1:R1=1 ; 2:R0=1 ; 2:R2=1"
ARM ISA2+dmb+pos-po+addr "DMBdWW Rfe PosRR PodRW Rfe DpAddrdR Fre" Prefetch=0:x=F,0:y=W,1:y=F,1:z=W,2:z=F,2:x=T Com=Rf Rf Fr Orig=DMBdWW Rfe PosRR PodRW Rfe DpAddrdR Fre { %x0=x; %y0=y; %y1=y; %z1=z; %z2=z; %x2=x; } P0 | P1 | P2 ; MOV R0,#1 | LDR R0,[%y1] | LDR R0,[%z2] ; STR R0,[%x0] | LDR R1,[%y1] | EOR R1,R0,R0 ; DMB | MOV R2,#1 | LDR R2,[R1,%x2] ; MOV R1,#1 | STR R2,[%z1] | ; STR R1,[%y0] | | ; exists (1:R0=0 /\ 1:R1=0 /\ 2:R0=0 /\ 2:R2=0) \/ (1:R0=0 /\ 1:R1=0 /\ 2:R0=0 /\ 2:R2=1) \/ (1:R0=0 /\ 1:R1=0 /\ 2:R0=1 /\ 2:R2=0) \/ (1:R0=0 /\ 1:R1=0 /\ 2:R0=1 /\ 2:R2=1) \/ (1:R0=0 /\ 1:R1=1 /\ 2:R0=0 /\ 2:R2=0) \/ (1:R0=0 /\ 1:R1=1 /\ 2:R0=0 /\ 2:R2=1) \/ (1:R0=0 /\ 1:R1=1 /\ 2:R0=1 /\ 2:R2=0) \/ (1:R0=0 /\ 1:R1=1 /\ 2:R0=1 /\ 2:R2=1) \/ (1:R0=1 /\ 1:R1=0 /\ 2:R0=0 /\ 2:R2=0) \/ (1:R0=1 /\ 1:R1=0 /\ 2:R0=0 /\ 2:R2=1) \/ (1:R0=1 /\ 1:R1=0 /\ 2:R0=1 /\ 2:R2=1) \/ (1:R0=1 /\ 1:R1=1 /\ 2:R0=0 /\ 2:R2=0) \/ (1:R0=1 /\ 1:R1=1 /\ 2:R0=0 /\ 2:R2=1) \/ (1:R0=1 /\ 1:R1=1 /\ 2:R0=1 /\ 2:R2=1)
