Executions for behaviour: "1:R0=1 ; 1:R2=0 ; 2:R0=0 ; 2:R2=2 ; x=2"
Executions for behaviour: "1:R0=1 ; 1:R2=0 ; 2:R0=3 ; 2:R2=2 ; x=2"
Executions for behaviour: "1:R0=1 ; 1:R2=0 ; 2:R0=0 ; 2:R2=2 ; x=3"
Executions for behaviour: "1:R0=1 ; 1:R2=0 ; 2:R0=4 ; 2:R2=2 ; x=3"
Executions for behaviour: "1:R0=1 ; 1:R2=0 ; 2:R0=0 ; 2:R2=3 ; x=3"
Executions for behaviour: "1:R0=1 ; 1:R2=0 ; 2:R0=4 ; 2:R2=3 ; x=3"
Executions for behaviour: "1:R0=1 ; 1:R2=2 ; 2:R0=0 ; 2:R2=4 ; x=3"
ARM MOREDETOUR0824 "DMBdWW Rfe DpAddrdR Fri DetourWW Wse" Cycle=Rfe DpAddrdR Fri DetourWW Wse DMBdWW Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Ws Orig=DMBdWW Rfe DpAddrdR Fri DetourWW Wse { %x0=x; %y0=y; %y1=y; %x1=x; %x2=x; } P0 | P1 | P2 ; MOV R0,#4 | LDR R0,[%y1] | LDR R0,[%x2] ; STR R0,[%x0] | EOR R1,R0,R0 | MOV R1,#2 ; DMB | LDR R2,[R1,%x1] | STR R1,[%x2] ; MOV R1,#1 | MOV R3,#1 | DMB ; STR R1,[%y0] | STR R3,[%x1] | LDR R2,[%x2] ; | MOV R4,#3 | ; | STR R4,[%x1] | ; Observed 1:R0=1; 1:R2=0; 2:R0=0; 2:R2=2; x=2; and 1:R0=1; 1:R2=0; 2:R0=3; 2:R2=2; x=2; and 1:R0=1; 1:R2=0; 2:R0=0; 2:R2=2; x=3; and 1:R0=1; 1:R2=0; 2:R0=4; 2:R2=2; x=3; and 1:R0=1; 1:R2=0; 2:R0=0; 2:R2=3; x=3; and 1:R0=1; 1:R2=0; 2:R0=4; 2:R2=3; x=3; and 1:R0=1; 1:R2=2; 2:R0=0; 2:R2=4; x=3;
