Executions for behaviour: "1:R0=0 ; 2:R0=1 ; 2:R2=0 ; y=1"
Executions for behaviour: "1:R0=1 ; 2:R0=1 ; 2:R2=0 ; y=2"
ARM ISA2+dmb+fri+addr "DMBdWW Rfe Fri Rfe DpAddrdR Fre" Prefetch=2:x=T Com=Rf Rf Fr Orig=DMBdWW Rfe Fri Rfe DpAddrdR Fre { %x0=x; %y0=y; %y1=y; %y2=y; %x2=x; } P0 | P1 | P2 ; MOV R0,#1 | LDR R0,[%y1] | LDR R0,[%y2] ; STR R0,[%x0] | MOV R1,#2 | EOR R1,R0,R0 ; DMB | STR R1,[%y1] | LDR R2,[R1,%x2] ; MOV R1,#1 | | ; STR R1,[%y0] | | ; Observed 1:R0=0; 2:R0=1; 2:R2=0; y=1; and 1:R0=1; 2:R0=1; 2:R2=0; y=2;
