Test S+PPO684
ARM S+PPO684
"Wse DMBdWW Rfe DpDatadW PosWW PosWR DpDatadW PosWR DpCtrldW"
Cycle=Rfe DpDatadW PosWW PosWR DpDatadW PosWR DpCtrldW Wse DMBdWW
Relax=
Safe=Rfe Wse PosWW PosWR DMBdWW DpDatadW DpCtrldW
Prefetch=0:x=F,1:x=W
Orig=Wse DMBdWW Rfe DpDatadW PosWW PosWR DpDatadW PosWR DpCtrldW
%x0=x; %y0=y;
%y1=y; %z1=z; %a1=a; %x1=x;
 P0            | P1             ;
 MOV R0, #2    | LDR R0, [%y1]  ;
 STR R0, [%x0] | EOR R1,R0,R0   ;
 DMB           | ADD R1, R1, #1 ;
 MOV R1, #1    | STR R1, [%z1]  ;
 STR R1, [%y0] | MOV R2, #2     ;
               | STR R2, [%z1]  ;
               | LDR R3, [%z1]  ;
               | EOR R4,R3,R3   ;
               | ADD R4, R4, #1 ;
               | STR R4, [%a1]  ;
               | LDR R5, [%a1]  ;
               | CMP R5, R5     ;
               | BNE LC00       ;
               | LC00:          ;
               | MOV R6, #1     ;
               | STR R6, [%x1]  ;
Observed
    1:R0=1; x=2; z=2;
