Test S+PPO456
ARM S+PPO456
"Wse DMBdWW Rfe DpDatadW PosWR DpDatadW PosWW PosWR DpDatadW"
Cycle=Rfe DpDatadW PosWR DpDatadW PosWW PosWR DpDatadW Wse DMBdWW
Relax=
Safe=Rfe Wse PosWW PosWR DMBdWW DpDatadW
Prefetch=0:x=F,1:x=W
Orig=Wse DMBdWW Rfe DpDatadW PosWR DpDatadW PosWW PosWR DpDatadW
%x0=x; %y0=y;
%y1=y; %z1=z; %a1=a; %x1=x;
 P0            | P1             ;
 MOV R0, #2    | LDR R0, [%y1]  ;
 STR R0, [%x0] | EOR R1,R0,R0   ;
 DMB           | ADD R1, R1, #1 ;
 MOV R1, #1    | STR R1, [%z1]  ;
 STR R1, [%y0] | LDR R2, [%z1]  ;
               | EOR R3,R2,R2   ;
               | ADD R3, R3, #1 ;
               | STR R3, [%a1]  ;
               | MOV R4, #2     ;
               | STR R4, [%a1]  ;
               | LDR R5, [%a1]  ;
               | EOR R6,R5,R5   ;
               | ADD R6, R6, #1 ;
               | STR R6, [%x1]  ;
Observed
    1:R0=1; a=2; x=2;
