ARM S+PPO173 "Wse DMBdWW Rfe DpDatadW PosWR DpDatadW PosWW PosWR DpAddrdW" Cycle=Rfe DpDatadW PosWR DpDatadW PosWW PosWR DpAddrdW Wse DMBdWW Relax= Safe=Rfe Wse PosWW PosWR DMBdWW DpAddrdW DpDatadW Prefetch=0:x=F,1:x=W Orig=Wse DMBdWW Rfe DpDatadW PosWR DpDatadW PosWW PosWR DpAddrdW { %x0=x; %y0=y; %y1=y; %z1=z; %a1=a; %x1=x; } P0 | P1 ; MOV R0, #2 | LDR R0, [%y1] ; STR R0, [%x0] | EOR R1,R0,R0 ; DMB | ADD R1, R1, #1 ; MOV R1, #1 | STR R1, [%z1] ; STR R1, [%y0] | LDR R2, [%z1] ; | EOR R3,R2,R2 ; | ADD R3, R3, #1 ; | STR R3, [%a1] ; | MOV R4, #2 ; | STR R4, [%a1] ; | LDR R5, [%a1] ; | EOR R6,R5,R5 ; | MOV R7, #1 ; | STR R7, [R6,%x1] ; Observed 1:R0=1; a=2; x=2;
