ARM S+PPO118 "Wse DMBdWW Rfe DpDatadW PosWW PosWR DpDatadW PosWR DpAddrdW" Cycle=Rfe DpDatadW PosWW PosWR DpDatadW PosWR DpAddrdW Wse DMBdWW Relax= Safe=Rfe Wse PosWW PosWR DMBdWW DpAddrdW DpDatadW Prefetch=0:x=F,1:x=W Orig=Wse DMBdWW Rfe DpDatadW PosWW PosWR DpDatadW PosWR DpAddrdW { %x0=x; %y0=y; %y1=y; %z1=z; %a1=a; %x1=x; } P0 | P1 ; MOV R0, #2 | LDR R0, [%y1] ; STR R0, [%x0] | EOR R1,R0,R0 ; DMB | ADD R1, R1, #1 ; MOV R1, #1 | STR R1, [%z1] ; STR R1, [%y0] | MOV R2, #2 ; | STR R2, [%z1] ; | LDR R3, [%z1] ; | EOR R4,R3,R3 ; | ADD R4, R4, #1 ; | STR R4, [%a1] ; | LDR R5, [%a1] ; | EOR R6,R5,R5 ; | MOV R7, #1 ; | STR R7, [R6,%x1] ; Observed 1:R0=1; x=2; z=2;
