Test MP+PPO920
ARM MP+PPO920
"Fre DMBdWW Rfe DpDatadW PosWW PosWR DpDatadW PosWR PosRR"
Cycle=Rfe DpDatadW PosWW PosWR DpDatadW PosWR PosRR Fre DMBdWW
Relax=
Safe=Rfe Fre PosWW PosWR PosRR DMBdWW DpDatadW
Prefetch=1:x=T
Orig=Fre DMBdWW Rfe DpDatadW PosWW PosWR DpDatadW PosWR PosRR
%x0=x; %y0=y;
%y1=y; %z1=z; %x1=x;
 P0            | P1             ;
 MOV R0, #2    | LDR R0, [%y1]  ;
 STR R0, [%x0] | EOR R1,R0,R0   ;
 DMB           | ADD R1, R1, #1 ;
 MOV R1, #1    | STR R1, [%z1]  ;
 STR R1, [%y0] | MOV R2, #2     ;
               | STR R2, [%z1]  ;
               | LDR R3, [%z1]  ;
               | EOR R4,R3,R3   ;
               | ADD R4, R4, #1 ;
               | STR R4, [%x1]  ;
               | LDR R5, [%x1]  ;
               | LDR R6, [%x1]  ;
Observed
    1:R0=1; 1:R6=2; x=2; z=2;
