ARM MP+PPO784 "Fre DMBdWW Rfe DpDatadW PosWW PosWR DpAddrdR PosRW PosWR" Cycle=Rfe DpDatadW PosWW PosWR DpAddrdR PosRW PosWR Fre DMBdWW Relax= Safe=Rfe Fre PosWW PosWR PosRW DMBdWW DpAddrdR DpDatadW Prefetch=1:x=T Orig=Fre DMBdWW Rfe DpDatadW PosWW PosWR DpAddrdR PosRW PosWR { %x0=x; %y0=y; %y1=y; %z1=z; %x1=x; } P0 | P1 ; MOV R0, #2 | LDR R0, [%y1] ; STR R0, [%x0] | EOR R1,R0,R0 ; DMB | ADD R1, R1, #1 ; MOV R1, #1 | STR R1, [%z1] ; STR R1, [%y0] | MOV R2, #2 ; | STR R2, [%z1] ; | LDR R3, [%z1] ; | EOR R4,R3,R3 ; | LDR R5, [R4,%x1] ; | MOV R6, #1 ; | STR R6, [%x1] ; | LDR R7, [%x1] ; Observed 1:R0=1; 1:R7=2; x=2; z=2;
