ARM LB+data+fri-rfi-fri-rfi-addr+OK "DpDatadW Rfe Fri Rfi Fri Rfi DpAddrdW Rfe" (* Combining three LB+PPO tests *) Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Rf Orig=DpDatadW Rfe Fri Rfi Fri Rfi DpAddrdW Rfe { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; LDR R0,[%x0] | LDR R0,[%y1] ; EOR R1,R0,R0 | MOV R1,#2 ; ADD R1,R1,#1 | STR R1,[%y1] ; STR R1,[%y0] | LDR R2,[%y1] ; | MOV R3,#3 ; | STR R3,[%y1] ; | LDR R4,[%y1] ; | EOR R5,R4,R4 ; | MOV R6,#1 ; | STR R6,[R5,%x1] ; Observed 0:R0=1; 1:R0=0; 1:R2=1; 1:R4=3; y=3;
