ARM DETOUR0865 "DMBdWW Wse PosWR DetourR DpCtrlIsbdR Fre" Cycle=Fre DMBdWW Wse PosWR DetourR DpCtrlIsbdR Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Ws Fr Orig=DMBdWW Wse PosWR DetourR DpCtrlIsbdR Fre { %x0=x; %y0=y; %y1=y; %x1=x; %y2=y; } P0 | P1 | P2 ; MOV R0,#1 | MOV R0,#2 | MOV R0,#3 ; STR R0,[%x0] | STR R0,[%y1] | STR R0,[%y2] ; DMB | LDR R1,[%y1] | ; MOV R1,#1 | LDR R2,[%y1] | ; STR R1,[%y0] | CMP R2,R2 | ; DMB | BNE LC00 | ; LDR R2,[%y0] | LC00: | ; | ISB | ; | LDR R3,[%x1] | ; Observed 0:R2=2; 1:R1=3; 1:R2=3; 1:R3=0; and 0:R2=3; 1:R1=3; 1:R2=3; 1:R3=0;
