ARM DETOUR0055 "DetourW DetourR DpAddrdW Rfe DpAddrdR Fre" Cycle=Rfe DpAddrdR Fre DetourW DetourR DpAddrdW Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DetourW DetourR DpAddrdW Rfe DpAddrdR Fre { %x0=x; %y0=y; %x1=x; %x2=x; %y3=y; %x3=x; } P0 | P1 | P2 | P3 ; MOV R0,#1 | MOV R0,#2 | MOV R0,#3 | LDR R0,[%y3] ; STR R0,[%x0] | STR R0,[%x1] | STR R0,[%x2] | EOR R1,R0,R0 ; LDR R1,[%x0] | | | LDR R2,[R1,%x3] ; LDR R2,[%x0] | | | ; EOR R3,R2,R2 | | | ; MOV R4,#1 | | | ; STR R4,[R3,%y0] | | | ; Observed 0:R1=2; 0:R2=2; 3:R0=1; 3:R2=0; and 0:R1=3; 0:R2=3; 3:R0=1; 3:R2=0; and 0:R1=2; 0:R2=2; 3:R0=1; 3:R2=1; and 0:R1=3; 0:R2=3; 3:R0=1; 3:R2=1;
