Test MOREDETOUR0782
Executions for behaviour: "1:R0=1 ; 1:R2=0 ; 1:R4=1 ; 2:R0=0 ; 2:R2=2 ; x=2"
Executions for behaviour: "1:R0=1 ; 1:R2=0 ; 1:R4=1 ; 2:R0=3 ; 2:R2=2 ; x=2"
Executions for behaviour: "1:R0=1 ; 1:R2=0 ; 1:R4=1 ; 2:R0=4 ; 2:R2=2 ; x=2"
Executions for behaviour: "1:R0=1 ; 1:R2=0 ; 1:R4=1 ; 2:R0=0 ; 2:R2=2 ; x=3"
Executions for behaviour: "1:R0=1 ; 1:R2=0 ; 1:R4=1 ; 2:R0=0 ; 2:R2=3 ; x=3"
Executions for behaviour: "1:R0=1 ; 1:R2=0 ; 1:R4=1 ; 2:R0=4 ; 2:R2=3 ; x=3"
ARM MOREDETOUR0782
"DMBdWW Rfe DpAddrdR Fri Rfi DetourRW Wse"
Cycle=Rfi DetourRW Wse DMBdWW Rfe DpAddrdR Fri
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Ws
Orig=DMBdWW Rfe DpAddrdR Fri Rfi DetourRW Wse
%x0=x; %y0=y;
%y1=y; %x1=x;
%x2=x;
 P0           | P1              | P2           ;
 MOV R0,#4    | LDR R0,[%y1]    | LDR R0,[%x2] ;
 STR R0,[%x0] | EOR R1,R0,R0    | MOV R1,#2    ;
 DMB          | LDR R2,[R1,%x1] | STR R1,[%x2] ;
 MOV R1,#1    | MOV R3,#1       | DMB          ;
 STR R1,[%y0] | STR R3,[%x1]    | LDR R2,[%x2] ;
              | LDR R4,[%x1]    |              ;
              | MOV R5,#3       |              ;
              | STR R5,[%x1]    |              ;
Observed
    1:R0=1; 1:R2=0; 1:R4=1; 2:R0=0; 2:R2=2; x=2;
and 1:R0=1; 1:R2=0; 1:R4=1; 2:R0=3; 2:R2=2; x=2;
and 1:R0=1; 1:R2=0; 1:R4=1; 2:R0=4; 2:R2=2; x=2;
and 1:R0=1; 1:R2=0; 1:R4=1; 2:R0=0; 2:R2=2; x=3;
and 1:R0=1; 1:R2=0; 1:R4=1; 2:R0=0; 2:R2=3; x=3;
and 1:R0=1; 1:R2=0; 1:R4=1; 2:R0=4; 2:R2=3; x=3;
