PPC MP+PPO209 "Fre LwSyncdWW Rfe DpAddrdW PosWR PosRW PosWR PosRR DpAddrdR" Cycle=Rfe DpAddrdW PosWR PosRW PosWR PosRR DpAddrdR Fre LwSyncdWW Relax= Safe=Rfe Fre PosWR PosRW PosRR LwSyncdWW DpAddrdW DpAddrdR Prefetch=1:x=T Com=Rf Fr Orig=Fre LwSyncdWW Rfe DpAddrdW PosWR PosRW PosWR PosRR DpAddrdR { 0:r2=x; 0:r4=y; 1:r2=y; 1:r5=z; 1:r12=x; } P0 | P1 ; li r1,1 | lwz r1,0(r2) ; stw r1,0(r2) | xor r3,r1,r1 ; lwsync | li r4,1 ; li r3,1 | stwx r4,r3,r5 ; stw r3,0(r4) | lwz r6,0(r5) ; | li r7,2 ; | stw r7,0(r5) ; | lwz r8,0(r5) ; | lwz r9,0(r5) ; | xor r10,r9,r9 ; | lwzx r11,r10,r12 ; Observed 1:r1=1; 1:r11=0; z=2;
