PPC MP+PPO198 "Fre LwSyncdWW Rfe PosRR DpAddrdW PosWW PosWR PosRR DpAddrdR" Cycle=Rfe PosRR DpAddrdW PosWW PosWR PosRR DpAddrdR Fre LwSyncdWW Relax= Safe=Rfe Fre PosWW PosWR PosRR LwSyncdWW DpAddrdW DpAddrdR Prefetch=1:x=T Com=Rf Fr Orig=Fre LwSyncdWW Rfe PosRR DpAddrdW PosWW PosWR PosRR DpAddrdR { 0:r2=x; 0:r4=y; 1:r2=y; 1:r6=z; 1:r12=x; } P0 | P1 ; li r1,1 | lwz r1,0(r2) ; stw r1,0(r2) | lwz r3,0(r2) ; lwsync | xor r4,r3,r3 ; li r3,1 | li r5,1 ; stw r3,0(r4) | stwx r5,r4,r6 ; | li r7,2 ; | stw r7,0(r6) ; | lwz r8,0(r6) ; | lwz r9,0(r6) ; | xor r10,r9,r9 ; | lwzx r11,r10,r12 ; Observed 1:r1=1; 1:r11=0; z=2;
