PPC LB+PPO0475 "PodRW Rfe DpDatadW Rfe PosRR DpDatadW PosWW PosWR" Cycle=Rfe PosRR DpDatadW PosWW PosWR PodRW Rfe DpDatadW Relax= Safe=Rfe PosWW PosWR PosRR Pod*W DpDatadW Prefetch= Com=Rf Rf Orig=PodRW Rfe DpDatadW Rfe PosRR DpDatadW PosWW PosWR { 0:r2=z; 0:r4=x; 1:r2=x; 1:r5=y; 1:r9=z; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | lwz r3,0(r2) ; addi r3,r3,1 | xor r4,r3,r3 ; stw r3,0(r4) | addi r4,r4,1 ; | stw r4,0(r5) ; | li r6,2 ; | stw r6,0(r5) ; | lwz r7,0(r5) ; | li r8,1 ; | stw r8,0(r9) ; Observed 0:r1=1; 1:r1=1; y=2;
